Where does this go? Brackets.
California
I lost my notes after these went to the plater's.
If you recognize anything here, I will be most grateful !!
Thanks.
Thanks, gentlemen. Meant to add years: all pulled off 1964-1984 FJ45 trucks and 1980-1987 FJ60 2F engines.
#1 is a heavy thick steel piece with a "L" stamped into its side--suspension/frame piece?.
Could #8 be off an air cleaner?
#7 (identical pieces) look like off the back of some electric/mechanical objects?
Maybe some poor fella's parts got tossed into my batch; maybe these came with a box o' parts I purchased? I keep looking at these this past year and scratching my head over what they are from.
Thanks for the help and suggestions.
Number 8 = part number 17313-61010 that holds the air bypass valve 4/78-7/80. Later year bracket was slightly different.
Number 6 bolts to the intake manifold and holds the temp sensor for the carb cooling fan.
Thank-you @Catfish28.
so whats left ?
#9 might be a exhaust mounting bracket tab of some sort
#7 Looks VERY Non Toyota o_O
same with #4
could be wrong ...
Thanks for the tips, Matt.
Three are identified: 5, 6, 8
Numbers 1, 2, 3, 9 are definitely Toyota. Number 1 has a LH stamp: "L" that I highlighted.
Numbers 4 and 7 might be something else I tossed in the bucket just to get plated. They have no tapped/threaded holes. Since the two #7 are the largest, I'm concerned that what look to be backing plates for some boxes--igniter, small "computer", electronic device--are waiting to be re-united with their "guts". Unfortunately I have accumulated too much stuff, in too many places, to notice what needs re-assembled. I have promised myself to be more careful with recording parts before they go off to other companies. One of the problems is jockeying between several different model years, deciding to delete certain functions and upgrade to later versions, and of course, the add-on stuff other owners installed years ago as we all do to "customize" our rides.
If identifying them goes no further, I do have a pile of "mystery" hardware, in case upcoming work comes up short and missing a widget.
I appreciate all the suggestions from fellow Mud members, and myself, rather enjoy trying to unlock the puzzles I see other guys post up here.
Nothing is desperate to be identified, and should make itself known if and when the time comes. Thanks to all.
