Where do you look for rust...
...when looking at one to buy? Looking in the mid-90s range, I live in Michigan, so anything close for me to look at will probably be rust belt/rough winters.
I am guessing this question has been asked before, so if there is a more thorough thread that covers it, please point me in the right direction. (Yes, I am also using the search function, just wading through the results right now)
Here is a good thread relating to older Cruisers. It may be of some help. https://forum.ih8mud.com/40-55-series-tech/132481-buying-land-cruiser.html
http://home.mchsi.com/~gregoverton/Buy.html
Check the e-brake because they seize up quickly. Check the bolts up around the body where it is hard to spray off with a power washer. The rear shock mounts were very difficult for me to get out when I put my lift on and I broke one of the rear sway bar bolts.
Do a search for threads with "rust" in the title.
There are a bunch of threads.
https://forum.ih8mud.com/80-series-tech/201509-comon-rust-areas.html
in/under/around/on the various dents.
FWIW last week I noticed (the first) rust appearing in an odd location on my 96; on the front left (US drivers side) of the hood. It started in line with the seam sealer and where the frame of the hood mate with the hood, so not sure if it was due to a crack in the seam sealer or due to water, salt, dirt getting stuck inside the underhood frame. The seam sealer was being pushed out by the expanding rust and the rust was coming up through the top of the hood. My suggestion would be to check all the usual places, along with all seams around the doors, hood, tailgate, etc. I cut off a short section of the bulging seam sealer and hit the rusty metal with rust convertor for a quick fix. HTH
