wheels spacer
Italy
Hello everyone....one simple question.....
wheels spacer yes or no?
i would like to mount the spacer, width 3cm (1,118 inces +/-)
in your experience it causes problems with the bearings ?
I've run 1" Bora spacers for 5 years without issues.
Don't buy cheap Chinese spacers. I have Spider Trax spacers Made in the USA for past 10+ years on my 97 Hilux surf and 6 years on the Hilux, no issues with so ever. Use thread locker and check the tighteness after like 100 km.
I ran Bora 1" spacers as noted /\ with no issues on my last 100.
The 1" pushes the wheels out to align perfectly with the fenders, subtle but noticeable difference from stock.
I run 1.25" SpiderTrax with no issues. Red Loctite and properly torqued to like 115-125ftlbs.
You have to go at least 1.25" unless your wheels have little recesses for the original studs to
hide in on the inside...I have steel OEM wheels that don't have the recess so I couldn't go
any smaller than 1.25". You can't have the wheel mating to the stud surfaces rather than
the flat surface of the spacer.
If you're looking for +/- 1.118", you may as well play it safe and go with the 1.25" spacers, IMHO.
