Wheels for disc brake conversion?
Kansas City area
I am thinking about buying the pro comp alloy wheels. They look a lot like the ICON wheels. The size is 15x10 with 6x5.5 lug pattern. Will these wheels work with my drum brakes? Will these wheels work with a future disc brake conversion?
I will run them through the winter with the drums and I will be converting to the manafre disc brake kit in the early spring. I don't want to buy a new set of wheels later! Any thoughts are appreciated. Also... Are the manafre disc brakes a quality upgrade if you don't want to do the mini truck conversion? Thanks
Why do you not want to do the minitruck/FJ60 conversion?
I don't like buying used parts or trying to track them down. I also don't want to grind down the ball! Sounds scary! I like new parts that don't require maint and any upgrade over these drums would be good.
Have people had bad luck with the disc brake conversion from manafre? I read all the posts and everyone seems to go back to these mini truck brakes. Why is that? Is it a money issue or a mechanical issue?
What yr & style is your L/C? What size tire are you wanting to run? Why do you want to run a 10" wide rim?
I'm not familiar w/the Manafre kit, but looking @ it, it seems it uses some aftermarket parts & course spline birfs. The mini truck/FJ60 & 79 & later model fj40 disc brakes are all Toyota parts & bolt on. It's beefier stuff. The grinding is minimal. It's just the evolution of design w/the L/C.
X2...I haven't used a "kit" from anyone, but think a few years down the road, are the kit parts going to be readily available at your local parts house? using Toyota parts, you just go down and get what you need.
spares are easy to get and swap if needed.
I have a 1975 with 4wheel drum brakes. I have the stock wheels currently, and the tires are the 33x10.5 bfg's. I was thinking 10" rims would fit the tires better and they would also provide enough room for the eventual disc brakes. The kit says it wont work with stock wheels. Why would I want 30 year old brakes when I can buy new disc brake kit? I'm not trying to be jerky, I want to know if there is a problem with the conversion kits. Thanks
i use the conversion kit and it works great. stops on a dime.. you will be happy with them. now that being said i have had them for 3 years but i am going the mini truck brakes sometime in the future.
You can buy new rotors & calipers for a Toyota @ most auto parts stores, along w/all the seals & bearings. A friend just serviced his frt end & purchased new rotors, calipers & seals. He pulled the birfs & repalced the inner axle seal, new grease, ect.. This kind of maintenance needs to done periodically. The design of those parts have worked well for over 30yrs. New cars today will need rotors & calipers @ some point.
Why are you going to switch and did you do the rear? Did you have to change the master cylinder or did the kit work with the original master cylinder? Thanks
i am going to switch so i can use the bobby long axles and i am using a gm master. and yes i do have disc in the rear. as far as the stock master i think it will work if you change the residuel valve. others wi;ll know the answer for sure
I don't mean to offend, but if you bought a 76 FJ40 you wouldn't be asking these questions, & stk wheels would fit. The only difference between the 75 & the 76 are basically the knuckles assemblies & birfields. At some point I plan on removing my 78 brake set up & go w/the mini or later LC knuckles for the beefier parts & longs. I do wheel mine alot.
One last question..... Would it be beneficial to buy larger diameter or width wheels? (meaning a 16x10) Thanks for the info on the conversion!!!!!!
mine are 15x8 and they work fine. i dont see any reason to buy a bigger size mine do clear the caliper. i do plan on buying a set of m/t 16x10 maybe in the future so i would have a wider wheel base by 4 inches without the spacer. not going to buy untill i need tires
i screwed up when i did mine and i already brought the disc conversion before i found out the longs would not fit. i only went wheelin once but i am going to do the same as you in the future. maybe one day in the winter when i am bored. i do already have the mini truck stuff just need to buy the bearing kit. i also have the longs too
Make sense to me! I am not a big off road guy, I just drive mine around town and throw it in 4wheel while camping. Sounds like the conversion will work great. I just want to be able to stop better while driving on the road. Thanks to all!
