I really have a hankering for hitting some trails. South island anywhere. Something a bit more on the technical/rough side? Or just getting to some nice/remote places. Anyone up for getting out for a day?
I wish! Just too far away
Fixed it.I'm absolutely up for another Hidden Lake trip this year. Already sorted that out with swmbo. The trip in those pics above was an excellent time; one of my favorite.
Responsibility is overrated, thats what I do. In 5 weeks I’m gone again.makes me want to ignore all my responsibilities, throw caution to the wind, and get away
Picked up a tool to help with “yard work”. The bonus will be it’ll also work well for clearing overgrowth off trails, etc. Only downside is its about 2 m in length so perhaps the chainsaw would fit better. The notion of an 8” carbide blade spinning at 10,000 rpm is both fun (& scary). “Safer” than a chainsaw because the part that’ll cut limbs off is anchored 1.5 meters away.
Nice! Those are very handy to have around. I'd like to use one of those on the blackberries growing over the rental house next to me - at 6 in the morning when the lazy fellas are trying to sleep in.
I used a stihl version to clear brush off old roads when I was a kid.
I've got a stihl 034 I lug around for bigger stuff that's in the way. Smaller stuff I just drive over. 'brushes' all the grease/oil off the bottom of my truck.![]()
Its been sitting for a couple years so it’ll need some TLC... after it’s not oozing gas when tipped the wrong way, you’re welcome to borrow it to clean up the yard. I’d suggest waiting till 7:30 or whenever bylaw enforcement won’t freak on you. The renters will still be equally happy. If you want we could also compare our Chainsaws, weed eaters, and the bush cutter to see what works best for various tasks around the yard
Do you have some trees that need to be cut up into rounds?
On a different day you can come over to my place and we piss off my neighbours who called bylaw enforcement because the grass in my back yard got too long. I’d cut it before they came... now bylaw is wants me to clean up the pile of grass clippings that are in a back corner of the yard because my green bin was full. I need a taller fence... one my pretentious, pain in the ass neighbours can’t see over. While I’m at it, 10’ high and concrete. Preferably sound proof. The neighbours got all excited and pissed off when, for the first time in 8 years, my dog barked in the yard for a couple minutes... 8 years. She never barks... never did until Covid at least. After listening to their garage band almost every weekend for the last 14 years... till 11 at night or later.
Sorry... rant over
I'd be up to it depending on when and where. If I'm off work I'd go.
Those things are the cat's ass for broom.View attachment 2389795
I removed a forest of it out back when we moved in. Old growth broom with 3" diameter stumps. If you scalp it flush with the ground when it's flowering it doesn't grow back, and the roots rot away in a year or two...the hundred million seeds on the ground are another matter. Apparently they stay viable for at least 60-80 years so it's pretty much impossible to fully eradicate. All you can do is make sure nothing flowers and no new seeds are dropped.
Wish they'd deal with it more intelligently with the highway crews. Mow that s*** down when it's flowering, not in mid summer when they're just helping spread the seeds. Or , crazy idea, treat it like an invasive species.
/rant.
Little Stihl I have the sawblade mounted on is just about dead now from all the broom killing abuse. When it dies I think I'm going to go for one of the multi tool ones. There's quite a few attachments I'd have a use for, and I'm well into the double digits on small engines around my place. Be nice to cut that down a bit.
As for wheeling, I wouldn't mind something mild...I definitely need a bit of a shake down run. See how many things I need to readjust or weld back on afterwards...
but first I have to see if I've found my shimmy, or I won't be going far.
Gets pretty savage above 80. I readjusted the toe, tightened up the steering box and the wheel bearings. They were actually quite loose so I'm hoping they were the problem.
Got it up to 90 past the graveyard on cedar road ( seemed fitting ) and no shimmy, so I think I got it.
Need a proper highway burn to see for sure tho.
I finished giving it a once over... replaced a cracked grommet, cleaned out the rust and water out of the pull start, and greased up the gear drive. I’ve got an 8” carbide blade and harness on the way. 1.8 hp engine spinning a steel rod and gear drive... connected to a carbide saw blade to spin it at 5-8k RPM. Fine piece of Japanese engineering that’ll cut through bush up to 3.5” in seconds.
Saw one video where they were comparing different blades. During the durability test the carbide blade cut all the way through the 2.5” steel pipe they were using to abuse each blade.![]()
