Wheel options to clear control arms?
New Orleans
What wider wheel options or backspacing are out there that can clear the control arms. I have 285/17 and they rub on the control arm on full lock, mainly reverse, what brands of wheels are options to push the wheel out but still have a nice offroad look, bead lockers a plus!
Thanks
I noticed most of the wheel options on tire rack are 17.8.5 1mm offset with 4.8" backspacing. Is this on par with the stock wheels or will this help push the wheel out some more.
Thanks
Thanks
The OEM wheels are 25mm offset. The lower that number the further it will stick out. Big difference from 25mm to -10mm plus a wider tire.
I am running an 8" wide 17" method wheel with 4.5 BS and -12mm offset with 34x10.50R17 BFG AT KO2s and it is perfect with my lift (but I have uppers).
17x8 -12, shouldn't that be a 4" backspace?
How do those 34's do on the body mount?
I am running 8" FN wheels f (x) Pro wheels, designed specifically for GXs with wider tires (with no wheel spacers). As a result, there is PLENTY of space between my 285/70 KO2s.
- Diameter: 17"
- Width: 8"
- Offset: 0mm
- Backspacing: 4.5"
- Load Rating: 2,100lbs+
- Weight: 23.88 lbs.
- Certification: JWL-T, VIA, SAE J-2530, DOT approved
106mm hubcentric for Toyota hubs, lug holes drilled for 12mm Toyota wheel studs for a sung fit on all 6 x 139.7 Toyota hubs
