Wheel Brake Cylinders
Hogan
Three on the Tree
Forest Lake MN
I have a 2/71 FJ40, and I need front brake wheel cylinders. I'm looking at CCOT, but they don't list my month/year.
Anyone here order from them for this m/y, and remember what you ordered?
Any help would be great.
Have you give Toyota a try? I remember paying around $50-$60 (with %25 discount for TLCA memeber) for each cylinder about 4 years back, these were higher quality than the aftermaket cylinders and fit perfectly.
Do you have a brake booster and dual master cylinder ( I think that you do) ? There was a bit of a transition going on about the time your cruiser was purchased, so it's important to pick the correct wheel cylinders. Check SOR for the correct year numbers.
Yes I do on both accounts
My 2/71 has the dual master and booster. It was 1970 that was the transistion year. FWIW I rebuilt all my stock cylinders using parts from NAPA.
I have the rebuild kits, but they are in such bad shape (rusted). I feel safer with new ones.
I just finished the rears and they where in way better shape.
Just bought some wheel cylinders from Man-a-fre. Apparently, they have better ones now that are made in Japan. Had my father go into the shop since he was in the area. They were 35 dollars each. Check them out if you want. Here's the link. http://www.man-a-fre.com/parts_accessories/brake wheel cylinder.htm I should have gone front disk brake while I have them exposed though.
I went through this a couple months ago. I have a 6/71 and I checked with CDan, and he said that they are DISCONTINUED from Toyota. If you are not going with disk brakes, your best bet is to rebuild them. Then, you will still have OEM. It really is pretty easy. Unless they are pitted badly in the cylinder, you should be fine rebuilding them. You can look on Coolermans website (you can see the link above on his post) to get detailed directions and pictures.
Good luck!
