Wheel bearing?
Columbia, SC
I am fixing to take my hubs and old rotors to have them pressed off and have new vented rotors pressed on. Should I replace the bearings while i am doing this, or is this something I can do later without having to seperate the rotor/hubs again?
I can easily inspect the outer bearings for wear, but it looks like the inner bearings may have to have the rotors off. I may just be blind, or dumb, or both, but I guess when I remove the inner hub seal that the bearings and races should come out. Maybe they don't have anything to with the rotors. Wow, maybe if I just type things out in the future I can answer all my own questions.
I am still wondering if am on track and if you guys replaced your bearings when you did a mini disc. conv.
Also what should I do about dowel studs for this other hub? One came with them and the other did not. Please link from hardcore section.
https://forum.ih8mud.com/showthread.php?t=110827
Thanks
Jeremy
I am doing a similar swap on my FJ55 and have decided to remove and replace all bearing while I am in there, I have been told if they look ok you can just leave em, but for me I have no idea where this truck has been so better safe than sorry. Pipe method worked great, forget using a puller.
Noah
Thanks Noah, I think I will add it to my order with C-Dan.
Good luck with your job, it's probably the messiest thing I have ever worked on.
Jeremy
