I am not a master mechanic, so I am having trouble wrapping my head around what you folks are saying here. ...
Grease isn’t a lubricator, the oil contained in it is. The lubrication (oil) need for bearings is very small, as the bearing operates a small amount of oil is liberated and lubes the bearing. The bearing should never have to push grease after the initial run in, it should be pushed out of the rollers path, but be close to them. Excessive grease makes the roller push, churn grease all of the time, causing higher drag, temperature numbers.
The best description that I found, from
here;
What is the problem with over lubrication? If a little lubrication were good, wouldn't a lot be better? Not really! Think about it this way. Picture yourself on a hot day walking along the beach. You go into the water up to your ankles, and as you walk along rapidly you feel cool and refreshed. Now walk rapidly in water up to your waist and you see the problem. It takes a lot of energy to get through the same temperature water and this would make you hot and fatigued instead of cool and refreshed
It's the same thing with lubrication. Too high a lubrication level and the bearing will consume energy as it plows through the lubricant. This energy will show up as heat added to the lubricant causing it to first lose its viscosity and then the lubricant will begin to form varnish and coke as it gets hotter. Varnish and coke are another name for solids.
From SKF,
here;
Excessive amounts of grease will cause the operating temperature within the bearing to rise rapidly, particularly when running at high speeds. As a general rule, when starting up only the bearing should be completely filled, while the free space in the housing should be partly filled with grease. Before operating at full speed, the excess grease in the bearing must be enabled to settle or escape during a running-in period. At the end of the running-in period the operating temperature will drop considerably, indicating that the grease has been distributed in the bearing arrangement.
From the Society of Manufacturing Engineers,
here;
With grease, more is not better. Excessive amounts can cause heating due to churning, which will deteriorate the grease. Approximately 20–30% of the open area between the races should be filled. Following the grease fill, a careful run-in period is required to fully distribute the grease within the bearing.
From
here;
The over-packing and over-greasing of bearings accounts for more failures than any other factor. Excess grease in a bearing cavity increases internal friction, which in turn raises the bearing temperature above the dropping point of the grease. This causes oil separation and eventually lack of lubrication. When packing a split housing pillow block bearing ensure that the grease cavity is only one-third full.
NTN bearing,
here;
The amount of grease used in any given situation will depend on many factors relating to the size and shape of the housing, space limitations, bearings rotating speed and type of grease used.
As a general rule, housings and bearings should only be filled from 30% to 60% of their capacities.
Where speeds are high and temperature rises need to be kept to a minimum, a reduced amount of grease should be used. Excessive amount of grease cause temperature rise which in turn causes the grease to soften and may allow leakage. With excessive grease fills oxidation and deterioration may cause lubrication efficiency to be lowered.
