What’s your float height?
outer space
I had to set and reset my float height to get the gas to be in the middle of the window last time I rebuilt my carb. My working carb float height is less than 8mm, somewhere closer to 7.5mm, and when running the gas is just shy of the middle of the window. When stopped, gas is exactly in the middle.
Wondering if anyone finds the 8mm setting to be perfect each and every time.
I would think it depends on the carb kit float seat spec., if it’s different from the original the float setting will be off, but then again I’d think the parts should be identical to original, dunno.
The carb I just purchased as a rebuild had the float set to 8.3mm. I didn’t check it to see where it landed in the bowl, but the seller had the rig running, so I’m going on a limb to assume it was middle of glass.
What’s the float height you’ve found that works?
Most of the kits call for a 7.5mm float level. When I lived at altitude, I took one to 10.5mm, didn't have an AFM just from experimenting and test drives and checking plugs. I haven't seen a difference in needle/seat measurements, some seats are different with 4 holes through down close to where the needle seats. I have seen different floats, one that would hit the little metal baffle and not seat the needle at 7.5mm.
Here in California, I'm running right about 8.5mm.
I’m in CT at seas level. I had to readjust mine a bit back after my rebuild and it was under. I brought it up to about 6 but I am feeling like I’m running low on an upward incline. I was gonna try running the car in my driveway where I have an incline and can rev the throttle. I do tho have some other issues that might be complicating matters.
Fuel in sight glass at half way mark.
And I blew air into my fuel line back to the tank the other day w/ a 60cc syringe (my compressor stinks) three times and when I checked the filter when I got home last night and it was almost half full.
I'd use this advice as a guide. So long as the fuel level is somewhere between the upper and lower markers on the sight glass while idling, you're good. It doesn't have to be perfectly centered. It doesn't matter where the fuel level is after the engine shuts down.
The float level is all over the place when driving off road. It's not super critical.
I think a good way to look at float level is like timing. Spec will get you there and it will run. If you want to fine tune and be OCD (guilty), float level is one of those adjustments along with the drop...and secondary slow cut setting...pump throw...etc (quite a bit of tuning is available on these beautifully designed carbs). The higher the mm on the float level setting, the lower the fuel level in the bowl. The lower the fuel level in the bowl, the higher the lift to get the fuel to the air horn, leaner mix.
Never give up, I did the same thing last week and had the same result! After flushing fuel line with air and retightening the lines back on the clear type fuel filter it then flowed with the filter half full of gas. My Toyota filter came in but I haven’t put it on yet.
In my case it ran fine when I had it set to 9.5mm (I got that incorrect setting from somewhere, don’t use it) and I could see the gas in the sight window between those marks (on flat roads) BUT when I hit an incline the truck died due to low fuel. Once I backed down the incline, I was able to start it again. I think it would have run fine forever if I lived where it’s flat but not where county roads can have a 8% grade.
I ended up adjusting it to where it’s at now (7.5mm) and runs great on all grades.
Reviving an old thread here but if fuel was at the top of the metal tab on the sight window, would that cause flooding and rough running?
TEQ carb book says 8mm. Use a 8mm drill bit to set float (without gasket)
