So, based on your VIN, it looks like your FJ62 was produced before the change date.Here's a change that went into effect October 1989 to be aware of, the flywheel bolts changed from 10mm to 11mm:
Toyota Service Bulletin dated 10-05-90
The length and diameter of the flywheel set bolt has changed. This results in changes to the crankshaft and drive plate as well.
Starting with:
Production Date October 1989
VIN JT3FJ62G*L1186060
Engine No. 3F-250226
The new short block assembly part number is 11400–61121 (was 11400–61120)
