Realistically, what would you do? Elocker or ARB? I am putting in a rear locker and I'm trying to decide between the two. I already have OBA setup ready anyway.
I wanna stay all Toyota, but really can't find a reason to NOT go ARB in this case. Comments?
Go ARB all the way. They lock faster than the Elockers, which can be critical when push comes to shubs . Or you could do Aussie rear and ARB front (like Me), little cheaper. Well, I don't have the 3rd installed yet but you get the idea.
Agree with Riad. The e-lockers are an advantage if you already have them, but if starting from scratch the ARB is an easier install, and stronger as well. You also don't need to replace the axle shaft for one with the long splines like on the elocker versions, and you won't have the issue of axle twist locking the axle shaft in the locker. He's also right about the "instant on" feature.
With ARBs a good set up is key to long life. Make sure someone experienced does it for you. For the compressor-get Slee's compressor mount and manifold. It makes a super clean install, and saves space under your hood.
I'm so happy with my ARB setup .. 4 years .. and 0 issues .. the same idea, if you aleready have e lockers .. nice .. but plan to buy new ones .. ARB .. !
I hope in the near future we have more options as auburn or eletrac..
Im just in the planning stage of my rig and have thought of installing elockers, then after reading all the posts on here I have decided to go with ARB
TJM here in Aus has a new Airlocker for landcruiser that from all reports is better than the ARB units are built more sturdy and have gotten a fix forthose peasky "O" ring issues and sucking oil up the Air lines.
Zack
Just got the reveiw here in front of me TJM have built a stronger and thicker carrier, larger bolts and a solid one piece cross shaft.
This is the route I am going on my 80, they have been out here a while now and are getting good reveiws.
Zack
Zack
there not available for the front as of yet, pretty much the same as the ARB jobs but with a switch that is less likely to break and then no crappy little spacer to be crushed (but then I haven't used them, my 100 has ARB lockers and the 80 has the toyota e lockers)
ARB locker is great. It's fast, reliable, strong and simple. I really like it.
If it breaks a line or compressor failure, leak, etc. it will stay in the open diff position (you wont have to try and limp home locked or trail fix it unless absolutely necessary)
I called TJM and they said they would have the lockers available this year. Still though why would you trust TJM and their untested locker, while ARB has a proven design.
