Amazon product ASIN B08WHLPQR3What diode did you use? Pic please? Good stuff.
You have to file the side down a bit to get it to fit, and it's a diode, so it only flows one direction, so you have to be careful to insert in the correct direction in the fuse spot. No biggie. Just check to make sure it's charging when you're done.
I did get a little impatient with filing the side plastic down and exposed a bit of the metal inside, but it works fine. Probably the same as the one posted above, but a lot cheaper.
