What Should I Do????
Charlotte NC
I have a 1975 Fj40 and an automatic transmission in it. The tranny uses a 203 style T-case. What should I use as a T-case??? I cant just use a 203 because it is full time 4wd and it is center output to the rear. What would be the cheapest option??? Any help would be appreciated. Thanks
:D
Good question I think you might have to swap in another axle because the land cruiser is the only vehicle I have ever seen with the side center section It would probably be easier for you to find a manual for it, because I don't know of any t cases that have the rear output off to the side.
If there is an adapter, AA will know off it.. Most likely they might be the ones making it ..
Give them a call at 800350 2223/805 238 7000, its worth a call .. Talk to the tech dept ..
Good luck!
You don't say what the auto tranny is but if its a turbo 350 there are abunch of Rover guys (also offset rear axle) who have mated this Chevy tranny to a Rover 231 t-case. It comes in a bunch of versions, is very strong, and has and under drive high range (use strong 3.7s in the diffs) and a very low low range (3.2:1) Some call it the poor man's atlas. Best part is it has a t-case brake and a lockable center diff. Pull the brake handle and you effectively select a front only drive for cutting brakes.
john0089 said:
Lets say I would get a new rear axle........What kind should I get?
Youy can adapt a stock T-case to it.
You could stick a Bronco 9 inch in the back (Close to TLC strength, stronger when modded) for cheap.
14 bolt for cheap (Rock grabber though)
Dana 60 etc. etc. etc.
I know they make adapters....but they are about $500 I would rather buy a used axle ($50) and a used 203 t-case ($60) and spend a little extra time. I still want to know if anybody else has a better suggestion.
GO TAR HEELS
Pick up a '86+ rear axle out of a mini truck (with the V6). It should be strong enough to handle the V8, has decent brakes, and is a six lug to match your front axle. It will be 3" wider though. If width is a concern, an 85 and older is the same width as your factory axles.
If you want a different tcase that will most likely bolt to the rear of you tranny than go for the NP205 from a chevy to match your passenger side front diff.
Yes it would if it is not a ford, but I thought that you did not want full time 4x4. Which is why i stated NP205 because they are a part time gear driven iron case that is extremely strong.
Or a land cruiser center rear.... They have coarse spline axles but maybe new ones could be had for less than an adaptor if you reused your center... Just a thought.
The 205 will fit your tranny if the 203 will. I just got into landcruisers and am still into the fullsize american stuff. Mostly Ford stuff. The NP205 was avaliable in Dadge, Ford, and Chev. Chev i believe from mid or early 70's to later 80's. They should be easy to find in any junkyard. I have two C6 NP205 combo's for my project truck but they are Ford.
bcon it would be nice to find an axle like you stated, but the availability just is not there driving the price up. A Ford 9" will work great and is pleanty strong (They use them in some dragsters) so I think it will stand up fine.
I honestly dont think availabilty is the thing, i would say its not real practical for anything. If you want a 205 in your cruiser then you have settled on altering the drivetrain to heavy duty stuff and a LC centered rear is at the bottom of the list for strength as its coarse splined axles leave a lot to be desired. If you want to change to fine splined custom, your out a few hundred but still have a weak pinion. That inevitable snowball effect is there as in where do you draw the line. As far as availability goes, i think i have 3 or 4 here in the shop and they arent too pricey. My opinion is that if you have a 40 with a small block and an auto, it is not a budgeting thing to do. Why put a 200lb Tcase in a cruiser just because its cheap so you can save on an adaptor and therefore spend lots on narrowing a D60 or 9" or whatever else. Then you saved on a adaptor to have custom axles that you wont have spares readily available for little money. Bite the bullet and get an adaptor or switch to a manual(cheap used) and retain the ability to replace what you break cheaper and easier since money is a concern. Too many options, none are perfect. Adaptor or weld up a cheap centered diff would be the cheapest overall. Good Luck, Eric
FWIW, I have read and or heard of guys using a center output Tcase with the stock rear axle. Yes it sounds goofy but it will work. Very early versions of the 25 and 40 series actually show this is some of the manuals, I have seen a pic of it on this board. Get under your cruiser and look up, Ever wonder why there is a round drive line hump squarly in the middle of the body and not offset to the passenger side? I think its because very early cruisers had a centered rear diff and an offset T case.
