What Should I Do????
To use a 205 you will need to use the factory T350/np205 adapter and the drive sleeve.
Make sure the 205 has a yoke on the back and not just a splined slip shaft.
9" is a poor 'cheap choice' due to the low pinion, 5 lugs instead of 6 for wheel mounting and many were only 28 spline axles.
My untested as yet FJ 40 has a t350/205 combo and I did a rear spring flip/spring over...but I redrilled the spring pads to allow the axle to move forward an inch and a quarter to keep a stock style flare looking right.
I disassembled the rear axle, ground out additional crown gear slots in the housing, switched the studs around on the diff housing area and remounted everything to get the diff to the drivers side.
With the left offset of the engine and the left offset of the rear axle housing, combined with the slight right offset of the diff housing, I now have the shaft angle in a great position...without buying a locally unobtanium mini axle setup. Don't bother to reuse the original spring pads even though you could...wrong angle. (In my springover anyway...)
Had to lower my crossmember a bit which I didn't like but it isn't any worse than a Chevy pickup so...I can live with it.
I modified a stock Chevy trans crossmember to slide up between the rails and used 2 1/2" crush sleeved bolts on either side. My skid plate has its own front and rear crossmembers and can be removed without touching the Trans crossmember for any needed maintainance.
Driveshaft angle is still downward quite a bit from a stock cruiser but its within range so its cool.
