what say you? crawl ratio
Not really, becasue you are not directly connected to the crankshaft you will get multiplication.
Go fo a noraml stall on the TC. High stalls tend to overheat on the trail.
Just to throw this in the pot, here's my SM465 to single Toy T case set up by Marlin with Toybox adapters and 4.7:1 low gear. It measures in at around 32" overall. Im running retubed toyota pickup drive shafts and 4.37 Mini Truck axles with flipped springs SOA on 35's. Using a double cardan in the back.
That's what I'd like to run. But I was thinking of SM420 instead of 465. Got any pics from your build?
Unfortunately, adapters are out of stock for 2-3 months. There is someone on the forum selling a SM465 adapter. Does anyone know if that will fit the SM420? Is the only difference the lock ring on the SM420 output shaft? Also, I've read some posts about potential front driveshaft clearance issues with the bulge on the side of the SM420 case. Is that something I should worry about? It's seems to be a non-issue w/ so many people on this forum running SM420s and a passenger side drop front axle.
I Say V8, Auto Tranny, 3:1 T-Case.
The only reason you would need any deeper gears, is if you have an underpowered engine, like a 22re.. then you need some gears..
Currently, I am running a 2F - SM420 - 4Spd T-case(1.99:1) - 4.88's and 35" tires.
Total crawl ratio is 68:1 Seems to work well.
I have been considering a 3:1 Orion - 102:1 and a stock split case(2.23:1): 76:1
I think the Orion would put me in the 'sweet spot'.
Any input?
SM465's are easier to find parts for should something kersplode. If you're interested, I have a spare 465 that I'd be willing to part with.
crawl math
Seems like a good thread to try to finally figure this out, can somebody break these numbers down for me so i can try to understand how this works. for example : h42 -crawl box4.7 splitcase-4.88 r/p and 35 tires. Thanks
And for those with auto tranny's you can multiply that formula by "2" due to the torque converter. 2 is an average of the multiplication you get.
