What rim size to choose 17" or 18"
I like 17's for my use case:
  • More sidewall looks better, IMO
  • Better for airing down off road, even if only marginally so. On road stability of my 17 tire setup was way better than my old 18 setup, though it's an apples to oranges comparison due to tire width (35x12.5x17 vs 285/75r18)
  • 17 tires are cheaper (at least in the US)
  • 17 tire options are 200% more numerous (at least in the US--this is just a guess, but I wouldn't be surprised if it's spot on)
  • Almost all 18" sizes suitable to the 200 are E-rated. I wanted to try a lighter load tire this time around for better ride comfort.
I would vote 17s as well. Only reason I went 18s are the cheap and readily available tundra take offs that can be found locally. So many more options for different load ratings for 17" tires.
I just went from 35x12.5r18 KO2 load E to 35x11.5r18 Wildpeak AT4W load C. Tremendous difference in ride quality.
this is a good point about 275 vs 285 in 18"
Availability: If you ever shred a tire in a remote area, you are significantly more likely to find a 275/65R18 or 275/70R18 at a small-town shop than your stock 285/60R18.
Point taken and is a factor in the trade space. It's worthwhile to note potentially other more important factors.
The right tire for use case and fitment should address first principles. What is optimal for daily use and will be a differentiator for that use case. I'd wager ride quality, traction, stability, handling, accident avoidance - these can be higher priorities.
The likelihood of a matching brand in even a common size is not likely. Availability of tires today with fast logistics makes it less of a concern unless one is really doing remote travel. Even there, other mitigations including using a stouter type tire, patches, plugs, spares , etc. would come into play first.
I'd focus on getting a great tire/size for the primary use case. 17s are a great size. But do it right, and even 20s can deliver a factory Lexus quality ride just as designed. I think too many turn knobs the wrong way in modifying, then believing only 17s can delivery a great ride. 275s IMO are one of those bad factors. So are KO2s.
You make a good point, Road manors and safety are of course an/the important factor when buying a tire and like you mention in case of a punture there are multiple ways of fixing the issue.
My initial post on availability (not something you have respponded to) was mostly aimed at the amount of tire options and brands. Most of the tires in that size are Chinese/2nd rate brands and not a preferance or MT/aggressive AT tires - which For my case are not needed. (which you mention in you post.
Just out of curiosity why do you not think 275 are good? 285 are 10mm wider (and the orignal width) Not trying ot bash or defend a "case" just interested in the opions/stats/know how.
Having checked various websites and done slightly more research it seems that the tire of choise will be a 285/70-17 BFG Trail-terrain
Reason: Although 285/65-18 is a genuine size it only has KO2 or wildpeak R/Ts available. The trail terrain is a more highway friendly tire for the odd gravel track, The least aggressive terrain tire avialable, and present as a OEM for certain manufactures. It is marketed as 3pmsf meaning i can drive further into the winter before changing to actual winter tires and don't have to worry about bad weather snow during/late spring.
Size wise only MT:s available in 285/65-18 and 70-18 and for 285/75-17 the price difference does not way up the 2cm in height
Now it is a matter of finding a fitting rim...
275s represents a downgrade relative to stock which certainly will result in compromised handling and traction. When there's win-win sizes like 285s and larger, I don't see a reason to give up handling and safety.
I drive pretty hard on even 37s, and it shouldn't be any surprise when there's significantly more sidewall and narrower fitments, it can give up a lot with more sidewall rollover and decreased traction. Unless more pressure is used to stabilize the sidewalls.
Which gets into the other point - 275s tend to have lower load capacities at equivalent PSI to wider tires. Tire pressure is a major factor to ride quality. With 285s, lower pressures will have a better balance of ride quality, load capacity, and cornering stability, versus 275s requiring something like 3-5 PSI higher with resulting compromises.
Agreed on availability for the size you're looking for.
Thanks you for your answer, all good and valid points, I had not taken the extra tire pressure into consideration.
I have proper skinnies 235/85/16 on my old defender never really thought about the cornering aspect, then again an old defender is not really a vehicle that drives fast or has road manors with flexy suspension so i guess the effect is not noticeable. Compare that to the 200 which is almost 1 ton heavier you do make a good case :)
Plenty of folks are completely happy with narrower tires. Over in the tire forum there is even a ‘skinny’ thread. There have been a few ‘traction’ threads and some YouTube videos about contact patch etc, no conclusive stuff I’ve seen says wider or narrower is better, it is hard to test apples to apples. I think a lot of people like how wide tires look. And manufacturers are happy to build what sells.
It largely depends on what exactly you’re doing, and what kind of mods you’re willing to make to fit wider tires.
I wanted to run 35s and wasn’t willing to do any metal mods, no fender rolling, no body mount cutting, etc. Am a happy 7 year user of ‘skinny’ tires in 275/80/18 and 35x10.5x17 (265) that measure “35” in circumference.
i think it still drives sporty with ‘skinny’ tires, but it is also a 7500lb SUv.
I think the tire load index is way more important for performance on and off road than the tread and width. Get a nice soft D load around 118 or 120 and enjoy your truck.
A 265 is already a wide tire. As recently as 15 years ago that was a tire width sold in the rear on Porsches from factory. It’s plenty wide. Movement in tire tech is amazing, and 315s exist, but unless you’re sand bogging, probably not going to make much of a difference.
There's examples from these boards where individuals tried skinnies. It might work for the leisure driver. Sometimes it doesn't if expectations are that it performs like stock. Handling traction and safety for accident avoidance is a real thing. At least three in this thread that had symptoms of poor handling, traction control kicking in, and disappointment with skinnies. Only for issues to be resolved when going back to proper width meats.
Don't skip leg day.
My 2c is I’d personally try to stay 285 wide or wider with tires. I’ve run 285/65/18, 275/70/18, 295/70/18, 35/12.5/18, and now 35/11.5/18. I personally felt that on road handling on windy mountain roads was negatively affected with the 275s. Day to day I did not notice a difference. Nor in the off pavement driving I did. So for some I can see that 275 would be just fine. But I’m in the mountains almost weekly in all seasons.
For me, the meaty 12.5” looked absolutely killer, but 11.5” or 295 seems to be the sweet spot.
There is a whole thread about that video, lol. Interesting observations, but testing one tire by one manufacturer on one (much lighter than ours) rig can hardly be considered conclusive. I do have personal first hand experience with ride and handling problems that I was unable to address via tire pressure with skinny 35's that all disappeared when I went to fat 35's. I air down into the low/mid teens, so fat tire on a medium width rim is also beneficial for bead retention. Again, hardly conclusive, just one guy's experience.
oh ok lol
I know sht about fk when it comes to the intricacies of tire sizes...the video popped up on my feed the other day, I guess because google is aware i've been searching tire related stuff in Chrome..
Outdoor Auto did another follow up video after Tinkerer that showed a significant increase in contact patch with wider tires when aired down...good watch.
Quick summary..
Wider Tires perform best for:
  • Deep snow, powder, deep mud, and sand: They offer superior flotation when there is no hard bottom surface to cut through (20:54 - 21:05).
  • Rock crawling: Testing showed that wider tires provide a significantly larger contact patch (up to 19.49% larger) when aired down to very low pressures (e.g., 8 PSI) (14:00 - 14:15, 21:06 - 21:13).
  • Lateral grip: They provide better stability for cornering and side-to-side handling (19:54 - 20:00).
Key Takeaways for Choosing:
  • Wheel size matters: The relationship between tire width and wheel width follows a bell curve. Using a wheel that is too wide or too narrow for a specific tire can hinder its ability to deform and reduce the contact patch (15:26 - 16:10).
  • Sidewall impact: More sidewall (often achieved with a smaller diameter wheel) allows for easier deformation and a better contact patch at low pressures (17:55 - 18:00, 23:30 - 24:00).
  • Tire Design: Ultimately, the intended purpose of the tire (towing/load-bearing vs. rock crawling) and its operating temperature range are often more critical factors for traction than the width itself (25:35 - 27:50).
  • Narrow tires excel in conditions where you need to cut through debris to reach a hard bottom, such as wet roads, shallow snow, slush, or shallow mud (20:27 - 20:42).
  • Wide tires are superior for deep snow, powder, deep mud, and sand, where flotation is required because there is no hard bottom to cut through (20:54 - 21:05).
anyone agree with this..?
I usually find his videos great. This is not one of them. The foundational premise is wrong and it isn't apples to apples as he implies. He's comparing tires with hugely different sidewall/load/air pressure characteristics. In this case, the narrow needs 80PSI versus the wide at 65PSI, to have equivalent load capacities. The narrows might as well be deflated compared to the wides at the same pressure.
Here comes and update with the results for those that have or had the same thought as me. I would also like to thank all of the people who participated in the discussion for their thought leading to a satisfying result.
The vehicle in question is a Euro spec 200 fitted with AHC
Rims: I choose to go with 17" since the amount of tire models was the largest. Additionally i do like the look and proportions of a 17" rim.
I ordered Evo course Dakar zero in anthracite (paint code 05) 8x17" ET 40
Reason: i have been looking at them for the last many years for other vehicles, and they were one of few brans with parts in stock ready to ship. I was on a tight deadline for my summer trip.
Review: Beautiful rims, Very tight and great fitment, Great quality and great customer service and looked better at in real life and on the car then i from what i have seen in pictures.
Tires: 285/70-17 Yokohama Geolander A/T G015
Reason: I was looking for the BFG trail terrain however when i was about to order the price had increased enough were i was not prepared to pay for the extra premium. The geolanders were offered at a good price and per sticker quiter on the road with the same fuel efficieny.
Review after 5500km: Nice quite tire. drives best at 2.8 bars at motorway speeds there is a slight howl above 80km/h but still acceptable.
Good grip in mud/gravel/wet asphalt but do pick up and sling rocks. Happy so far.
Tires bought from 1001tires (google for there specific website for your country (europe)
Additional thoughts:
Going from a 305/50-20 to a 285/70-17 Reduced the wheel mass significantly and the vehicles overall acceleration and handling were improved.
The 285 Fits perfectly with slight rub at full lock against the front mudflaps. With a 275/75-17 it looks like it would not have fit without removing the mudflaps.
The tires were mounted with the black side out for a "bigger" look and addtionally the white text would no clash with the lettering on the rims.
Hope this info can help some one out with their tire and rims choise.
I will try and make a build thread with more info and pictures of the trip in due time
As this thread got floated back to the top, reminds me here's a much better test that draws more balanced conclusions.
