What model 40 to build?
Texas
Website
www.peopleschoiceins.com
I need to figure out which model to build. I want to build a 40 for a second or third car. I like all the gadgets, creature comforts, etc. I already have an 80 and am buying a 100 for my wife soon. I want the 40 for occaisional driving and or for one of my sons.
I know some of the later ones came with PS and AC. Which years were they?
Which models make the best toys?
Suggestions?
Basically, the newer the better, for a couple of reasons? The 79 and later trucks have better on road gearing (not as good for off road), larger fuel tank mounted underneath the body, and developed more and more convenience items as time went along. Only 79 and later trucks have FACTORY air and ps, but they can easily be added to any 75 and later if you wish. Plan to pay a large premium for a truck with factory air and ps, not many around. Additionally, late model truck value is higher in general for resale, for all the reasons above, with of course the 83's demanding at least a 25% premium, last year imported to the us. They're all land cruisers, if you don't care about resale, or intend to do serious off roading, scratch most if not all of the above, and build one the way you like it. There are rabid fans of each year, I've owned most all year models, and have yet to own one I wasn't proud of.
Personally I think that 78 is the best year.
For a lot of reasons but I like the 4:11 gears best for offroading. Anything after 76 would do you just fine, 79 and later are a bit better for "on road" driving. However, we are talking about a 40, so you are going to get much "utility" in one of these older rigs.
Have fun!
Rezarf <><
best years
Anything from 1976 to 1983 with the best overall deal you can afford. I would rather mess with mechanical problems that body rot.
For what you describe I would get a 79 or later. Personally I like the 81 and later (technically production dates of later than 8/80). These have the split transfer case, and rear heater built into the console. The seats are also nearly identical to FJ60 seats. Late model cruisers usually run a bit more $$. You can find a deal though, I bought an '82 FJ40 with the cleanest tub I've ever seen on any unrestored cruiser for $3000. Happy hunting.
Is Smog an issue where you live? If so get an old truck that dose not need smog. You will also find that the older trucks have thicker sheetmetal and are less likly to rust. All of the up grades can be done to any clean truck.
for a/c trucks, factory will be very hard to find. CCoT or other aftermarket kits are going to be the norm.
PS systems (oe) were more common, but saginaw and mini truck are more common and an elegant saginaw outperforms a mini truck.
....don't know if you can still buy all the parts, but any 1973-1984 steering column can be converted to locking style (I've done this with my '81)
Consider smog issues, and if applicable I'd stick with '73-'78. If your willing to trouble shoot smog, I'd get an '81-'84 as the engine is identical to any FJ60.
Tubs have been rehashed over and over, but if you enter a late model project with using a Paul Pilgrim /Panama/Heritage tub straight off, all your rust issues are solved.
I don't like E-1972 trucks and 1979-80. Being that most trucks will be 25 years or older you will look at, many are non original so shopping for options off the assembly line is irrelevant.
