What Low / High Pressure for the AC? 1999
SAT
Just charged our '99 for the 1st time and it seems to be cooling the same as before but not sure.
I put in the required amount of refrigerant but the Low side pressure was at 50 and the high was at 360m both of which seems high? I've searched but I can't find what it's suppose to be.
Are these reading in PSI? Did you use cans or a machine to charge the system? Was the system completely empty?
Correct in that the readings are in PSI and I used cans. System was evacuated prior. Yes, I vacuumed the system.
The gauges I used were a loaner so I'm not trusting the reading. I ordered my own Mastercool set and will take readings with it following the posted service manual guidelines.
The readings I have posted above just happened to be under the service manual guidelines as well but with the rpm at 1,500.
Do you remember the ambient temperature? If it was 100 degrees that could be normal. If it was only 70 degrees, then its high.
Could be overcharged. Could be an issue with the condensor(poor air flow, or blocked fins, basically not cooling). Was the fan turning on? It should have been if it was at 300+ psi.
Here's a great video on sort of general A/C diagnosis. goes over diagnosing pressures. jump to about the 18:20 mark to see the part about high pressure causes.
After returning a leaking gauge set, got one that works really well, and took readings;
AC full on, Fan on highest setting.
RPMs held around 2k
Ambient temperature 90*
Low Side = 44 psi
High Side = 340 psi
The ratio is greater than what the service manual notes as posted above.
In other AC charts, for 90* they say 45-55 for low and 250-270 for high.
