What is this?
Forest Falls, CA
Website
www.adventureduo.com
Im thinking this might have to do with my weird idle issue...
.. found it today. Hose came off from wash board roads.
What does this item do?
x2 I also wondered what it was. but since it didnt break I didnt ask.
Agreed that it's a VSV of some sort. Looks like hose has been off for quite some time - how long have you had weird idle issue?
Of course, hook it back up and report back any changes :)
SOCALFJ,
It will definitely make your idle erratic. It was the source of my problem when I first bought mine. Seems the hose gets pretty brittle and won't stay on, even with the spring clamp.
SOCALFJ,
Great news!!!! Im stoked if this is the fix! Ok, after work im fixing it. I'll post back up.
Trucks been running weird for weeks and i even replaced the air flow meter! (thank god a junkyard one).
Well, that is NOT the VSV...VSV is more inboard, stuck to the bottom of the intake. I used to remembe the name of that device, but it escapes me right now....look the pic on this thread and you'll see. It's a vacuum operated valve of some type as someone stated earlier.
https://forum.ih8mud.com/showthread.php?t=185001
Try this:
Remove your fuel cap, is there a woosh of incoming air?
That little hose and a tight gas cap work together.
If your 93 has the same set up as my 97 I think that would be the vsv for the egr....and it probably used to be bolted up on the underneath side of the intake right in that area. REAL fun to remove and replace. Maybe someone has dropped it down and messed with it previously.
Try this:
I always have a ton of air coming out. But i have dual tanks.. so maybe thats why.
So what... don't tell me a bad cap can be causing the problem?
Probably not in this case, but since this engine relies heavily on VSV's for vacuum almost any lose or cracked hose, oil filler cap, dipstick and so on could be part of your problem.
Yours is VSV for EVAP mine was off last week after an oil change.
As for idle issues...high idle issues...mine went away after cleaning the IAC and a slight spring stretch.
Also check your TPS, pull it up by hand and work the rpms manually.
Yes, that hose attaches to the VSV for EVAP which sucks fumes from the charcoal canister. As you found it it doesn't really matter much if it's on or not except for the fumes. My brother in law's 93 had that thing adrift for some 3 years and ran fine. I literally just put it back on an hour ago as I checked it over for a long trip next week.
The VSV is farther out of sight under there.....
DougM
Ok, well.. was up till about midnight working on the idle issue. We pulled the IAC first. Someone has already pulled it in the past cause it had the HEX bolts already woohoo! So that came off easy. We tested it and cleaned it. Works fine. We cleaned the tunnel and wiped it out also. Sprayed some cleaner in the intake port and fired the truck up while doing so. Now everything looked cleaner, but wasn't too dirty to begin with. Then we pulled the TPS. We cleaned that. We also tested it and it works fine also. Then we put it back on and made sure it was adjusted correctly with the gap test on the throttle stop. After that we yanked the intake hose between the air flow meter and the TB. We took that into the bathroom in the dark and shined a flash light through it. No holes/leaks of any kind. Cleaned the TB as best we could and wiped the butterfly while in the open position. Put that all back together.
Fired the truck back up at just about midnight. Idle is back to normal. Truck no longer dies. We'll see how long it lasts. We have a overland trip for Thanksgiving so i hope we are out of the woods with this stupid idle issue.
PS.... does your intake hose between the air flow meter and TB stink like fish??? LOL
Be careful with your knee on the radiator.
bit of a risky position, there... eh?
added: or is that *risque*? :D
I became a bit concerned when you said "we" went into the bathroom in the dark. Then something about the air intake smelling like fish;-0
