What is this pulley bearing called?
Marietta, GA
What should I search to find the replacement/fix for this pulley bearing going out? I've gone through the owners manual and can't seem to identify the part. Those that might know the part, can I replace just the bearing (I'm assuming that is the broken piece), or do I have to replace that whole part surrounding the pulley shaft? Thanks for helping a newbie.
That's your power steering pump. You may be able to get away with just the bearing, but I doubt it. More likely the entire pump needs to be rebuilt or replaced judging by the angle of the shaft.
3B engine ?
Factory Service Manual page SR-40 is quite clear about the components and most of them should (still) be available at the dealer or through Web part suppliers.
Bearing : 90363-17004 -> cross referenced with a LOT of other application
Gaskets rebuilt kit is available :
04446-30010(10/1982 - 10/1984)
04446-35010(11/1984 - 07/1987)
