What is this component?
Charleston, South Carolina
I was doing some work underneath on a 94' 80 I bought a couple months ago and stumbled on this component over left rear axle. I thought it was some kind of junction box for brake lines and then I saw a grease fitting on it. The fitting also had a little rubber hat on it. Anyway, I'm
probably the only guy on the site that doesn't know what this thing is but what is it? Also what kind of grease and how much grease should I add to it?
By the way do those shocks look original to truck? Thanks
That's a brake fluid bleeder not a grease point. It's called a LSVP, as the truck takes a load and the rear end sags it adjusts pressure to your rear brakes for better stoping power.
I'm about to do calipers, pads and rotors on the rear and that thing looks really rough. Would it be a good time to replace?
Not sure about replace, but if you are bleeding your system for a brake job this could come into play on the bleeding process. Like said search "LSVP".
The LSPV is part of your general brake bleeding system. You go from the furthest from the master cylinder and work your way in. The LSPV is bled after the rear brakes. The condition of the outside may not necessarily indicate the condition of the inside but if the case may be, the LSPV is easily rebuildable with the OEM kit. Most people forget to bleed this but its the high point for the rear so there is always bubbles that get trapped there.
EDIT: by the looks of the rust I would spray liberally with a rust penetrant of your choosing and let sit overnight before attempting to move that bleeder screw.
