I couldn’t find this via google. Just something I noticed and was curious.
I believe 2002+ had rear AC standard. I have an ‘03Most likely where the rear heat (or AC, I can't tell) button would be.
That is the blank for the rear heater blower.
But if the 2003+ has rear HVAC as standard...and the dashboard was redesigned for the 2003+ model year...why is there a switch blank?
Behind the climate controls is a large circuit board with all the lights and buttons and connectors so modifying it would likely break something else unless you carefully map out the real estate back there. You’re pretty much limited to whatever OE switch covers are available and I doubt there’s many. Maybe a JDM 100 has a cool option or two we didn’t get?Would be a really cool place to put an OE switch for light pods or maybe drill out and put a CB mic jack.
Spressomon has done this. He says there is a twelve-volt off-on-on output, doing exactly what you want.I popped off my blank cover (old-style '98 dash) and the mirror heater button beside it, they're identical underneath. Both switches are monitored by the ECU with backlighting and an LED indicating "ON".
Assuming that the ECU toggles some accessible wire when the blank button is pressed (hell, you could even use the signal to the "ON" LED and buffer it), it wouldn't be difficult to 3D print a custom button cover for the blank space and wire up a relay that controls something. Any ideas?
But under the driver's side front seat is the connector you can pull 12v power from that is switchable via the rear heater switch apart of the center dash console. You don't get separate "High or Low" switching but get "Off, On, On" though including the green LED showing the on, on and off positions!
