What have you done to your Land Cruiser this week?
holy cow - batman ...
i have done so much. finished 8274-50 install. new front bumper. new rear bumper. new seats, front. new seat belts, front rear. locker install ARB, front and rear, ARB compressor install, auxliary air tanks install, replaced floor under drivers seat, reconfigured spare tire mount and made an extension to place it up and out of the way, installed CB antenna mount, painted most of the front end.
going digital on the vehicle lights. electrical next. then roof rack. finish painting.
wow...that's what happens when your havin fun ...:clap::clap::clap::)
no time to post either.:hhmm:;)
Started pulling up the bedliner that PO had installed in the interior. I found a ton of rust. I think I'm in "new tub" territory but I don't have the money right now. I'm probably just going to POR it all, cover it back up with bedliner, and drive it until I can get a new tub.
Installed new exaust 2.5" with a flow master mufler- from the header flange to the tail pipe, all new.
New headlights, and fixed troublesome turn and running lights: (had 3 wires crossed, at least one shorted wire, one half burned out bulb, the left running/turn light wasn't grounding properly, and a loose fuse - geesh!). Installed new air horn and side view mirror. Tonight I will adjust those new eyes after it gets dark. This week is inspection and Texas plates!!! Anything else? Bring it on...
Installed mud flaps and tail pipes
Replaced tail lights broken at Round Up. Figured out I have an electrical issue related to my rt frt turn signal. Replaced a blown fuse and after sucking rich exhast gas for way too long, discovered that the buterfly on the automatic choke was adjusted full the wrong way....few turns of the screwdriver and bingo, big part of the running rich problem solved. Also discovered screws for dist dust cover were poking thru cap causing a good shock when you touched them. Replaced plugs, cap and rotor.....during which I noticed throttle cable was three threads of wire away from breaking...built a new one. Wonder why I never have time to work on my 79?:bang:
Striped most of the rig this week. Having a little trouble with the windshield bolts might need a bigger hammer to encourage them to come out and then it is off to the blasting shop. Nothing better than clean metal...maybe painted metal and put back together.
Sent SM420 input shaft to Novak to be modified.
Switched the insurance from Nevada to Texas - replaced the final light bulb so all running/turning/stop lights work.
Ready for DMV inspection tomorrow and Texas plates.
Funny - in Texas you have to register your rig first - then they let you get a drivers license ;)
Just got my new bumper completed....AMAZING
New bumper hand crafted by Vic at VORFAB in Mountain Home Idaho...this guy is AMAZING. His work is bar nun!!
dont forget to get inspected first need it before registration. and get a vir30 (might be vi30) since its from outta state.
