Are 4:88's the same as 4:87's?![]()
So with all this gear talk and wisdom being discussed here, can anyone recomend a good place ( preferably online ) that I could purchase a couple of ring and pinion sets along with the necessary install kits?,,, and is this something the average guy can tackel himself ? -I'm not a rocket scientist nor a caveman- but something in between with some mechanical skills.
don't have a welder.....................
looks simple but mucho complicated.BTW, 4WIW, I have read countless mag's and other sources and 2MK I think they ALL imply you can "set up" the gears without a pinion depth tool or gauge.
This has always been a quandary for me, and if I had the money Summit has one, costs more money than initially thought of but 2MK you will set up the diff THE FIRST TIME right and not have to re shim the pinion if incorrect. And it is reusable, win win to me![]()
This is my opinion, 2MK and.........AND the artical I read in P4WOR specifically for IFS Toyota in the pictures, the tools they bought from Randy's R&P where the same one's you get at Harbor Freight![]()
Randy's is good (ring-pinion.com I think) .
Installing a R&P takes experience and special tools, considering you can trash a lot of $ worth of parts if not done right, it's best left to the pros.
( don't need the welding books or dvd's - do have a welder though), thanks again.I have welding books and welding DVD's
My point? Do some intel get the FAX, its not ez shop press is $200 at HF, definitely multilooks simple but mucho complicated.
