Pighead said:That's one screw I do Know, Idle mixture screw.
fyton2v said:That's the idle mixture screw? Then what I REALLY need to know now is this... What is the screw that is at 9 o'clock if that picture is oriented so that the gold screw facing us is at 6 o'clock. It's the screw that faces the firewall. I'm pretty sure that the screw in the pic faces the head. I thought that one was idle/mix.
Man, do I love working on this car in the middle of the night.
Thanks!
cruiserwanted said:Please refrain from calling your cruiser a car. It is quite upsetting.......
Good Luck with the adjustments.
Pin_Head said:The screw in the base between the two throttle shafts is the main idle speed screw and it is not visible in the picture b/c it is behind the spring. The top screw you can see is the throttle positioner speed adjuster that regulates engine speed by the smog computer during dece3leration. The bottom screw is the fast idle associated with the choke.
HTH
