Thanks! Bone stock '02 HO with the exception of an upgraded lift pump. Love the 6-speed for towing.Fine looking second gen!
Next were the two large circular holes for sender and pipes.
These had 5 x m4 tapped holes , most of which had snapped off studs within.
Stud extraction is not gonna work. So a metal hole punch in some thin steel plate , weld onto the studs and surprisingly they all came out, some needed a few attempts, but a good result already round.
The tank in due course will have a full re vamp and new coats of paint
Love that Michigan has gone back to the retro plates being an option. The one with the Mackinaw bridge has been the plate for nearly 30 years.Drove the heart transplanted 79 home today. It runs well. There are some shakes and rattles to sort out, plus a list of fix ups to do for the season. Tomorrow I'll get the headache rack on and bed steps on. I'm hoping to drive it regularly for a couple weeks before putting the camper back in to make sure it is ready.
My new plate came in too (really it's a wanna be since it is a Frankenstein, and doesn't have an FT, but close enough for me)
I am a total 1fz fan boy, but sadly, the valve seals just can't match the durability of the rest of the engine (as long as it never overheats).Replaced my valve guide seals, second time this week. Must not have got one full seated the first time. Gave them a tap tap with a small hammer this time. View attachment 3892749View attachment 3892747
Happy to say I now have a leak-free, non-smoking 1fzfe, for atleast a few days. Attempt 1 took about 8 hrs, but I got it down to 4.5 this round.
This crouching/ sometimes belly board is a necessity for the job.
Can someone explain this to me like a noob mechanic?I am a total 1fz fan boy, but sadly, the valve seals just can't match the durability of the rest of the engine (as long as it never overheats).
Certainly not an exclusive problem to toyota or any other engine.
Quite a project, but gratifying at every startup NOT seeing the little cloud of blue smoke! Nice work
i'm surprised you didnt have to open at least a 3rd beer when you remembered those werent phillips heads and had to grab the JIS driver1) remove 3 phillips head screws, pull out tailight assembly - open beer #1
Probably sacrilegious but rhino liner?Thinking of what i am going to to with this bed. Not happy with this solution from previous owner. Too much bare paint exposed. Wanted to just throw an original plastic tub in there. Impossible to find/afford. Any ideas?
I was thinking the same, but Raptor liner, color matched sprayed with the really fine settingProbably sacrilegious but rhino liner?
Spray in bed linerThinking of what i am going to to with this bed. Not happy with this solution from previous owner. Too much bare paint exposed. Wanted to just throw an original plastic tub in there. Impossible to find/afford. Any ideas?
Just saying that the little valve seals that slide over the valve stem don't hang in there as long (or half as long) as a 1FZ engine does before it needs a rebuild. They do an awful lot of work in their lifetime. In their defense, I can say with experience that the Toyota valve stem seal lasts a lot longer than aftermarket (FEL PRO) seals.Can someone explain this to me like a noob mechanic?
Or have to open a 3rd beer because of the extra exertion needed to lean on a phillips screwdriver to keep it from camming out on a jis screw!i'm surprised you didnt have to open at least a 3rd beer when you remembered those werent phillips heads and had to grab the JIS driver![]()
