Beno, cradles from Japan?
I put a layer of windshield bedding compound under that cowl/windscreen frame gasket.
I don't want anymore rust under there.
3M Auto Bedding and Glazing Compound 1/10 gal cartridge 08509
Available in the US market.
I assume you used the 1991-1992 MC for trucks with disc brake fronts and drum rears?
Did you have to modify your tubes at all?
Can you verify that part number? My aging eyes make it hard to read. Is it 63010U2? Did he box carry the same part number?And the NSK bearing number for your PS IDLER/adjuster pulley. This will be useful down the line for replacement since the bearing is not available separately from the pulley from Toyota and the pulley is discontinued. Applicable for 3B and 13B-T engines with PS:
Any idea if this will work on the other two idlers on a 13BT with A/C?
Beno
4 inch angle grinder with metal cut off discs first and then a 4 inch grinding stone to clean the welds back. Easy mate just take your time cutting and checking as you go.
Thanks Onur. Only reason I asked is that I cannot find that number on NSK's websiteI cannot verify the other idlers since my simple 3B only has an idler for the PS belt. Someone with a 13B-T apart will have to verify since toyota gives no information on the bearings in the EPC.
The number looks correct Sam.
| Rolling Bearings | NSK Online Catalog
