What did I do to fawk up the plugs in my garage?
Hey everyone,
I have an electrical question for those of you who know about those things. In my garage I have 4 plugs, all on the same breaker, one on each side wall and two on the back wall.
Well I had my x-mas lights plugged in outside to the garage plugs. One extension cord ran from the plug to a "power strip", to which the lights were plugged into. Over the weekend it rained and I guess water got into the power strip. Well tonight I moved the extension cord, and smoke came from the power strip, and all the plugs went dead. The breaker was not tripped, but the plugs are dead, all 4! So what the hell did I do? I assume that I must hire a pro, but at least I want to know what I am looking at? Did I fry the breaker? Why didn't the breaker just trip? I know that none of the plugs are GFI's. So what the fawk did I do?
Thanks,
Zack
Is there a second GFCI that is controlling your outlets? Newer homes usually have a GFCI in the garage, how about one of the bathrooms? Push the test button on ALL GFCI's in your home. Generally 2 in the kitchen, one in a powder bath, one or two in the garage, check the master/secondary baths. There will usually be a GFCI in the master water closet if you have a powered Jacuzzi style bath. Any outside GFCI's like on the back patio??
The garage plugs should be GFI. The gfi breaker is not always located at the panel or in one of the garage outlets. Look for a GFI outlet in another outlet like a bathroom or outside outlet.
x2.
I just checked, and there are no GFI breakers or plugs at all. The garage is basically by itself. The original guy that did the work was shadyat best, so it comes as no surprise. But without the GFI, what do you think that I might have fawked up?
Thanks,
Zack
Attached or detached garage? Subpanel in the garage? If so, have you checked the main panel? Need a little more info.
Well when the garage was added the original house panel became the sub-panel, and the garage panel became the main panel. So the plugs in the garage are run off the now "main" panel. However I did look at the house panel, and all is fine there as well.
Thanks,
Zack
With all 4 garage outlets dead, I would suspect something at the main breaker for that circuit. Try removing the cover from the panel with the affected breaker in it. The breakers just snap in. Unsnap it, or pull it out and re-seat it. May have a poor connection where it snaps onto the main bus bar.
Don't touch anything that is shiney or not insulated. If this fixes it, you may have a corrosion problem that is causing a poor connection. This can result in over-heating and a panel fire.
How old is the garage/wiring?
Well everything was done in 1997. Is it possible that I burnt out the breaker? If so I can run to Home Depot and get a new one.
Thank you all VERY MUCH,
Zack
Zack
It's possible, Zack.
If you can locate the suspect breaker, Take off the branch wire that is connected to it off and re-connect on another similar sized (amperage) breaker and see if that gives you any juice.
