What are others doing when their VAF’s go bad? ‘94 FZJ80
It's basically some potentiometers that are adjusted by the barn door.
I have a pdf somewhere of a troubleshooting guide for a bosch VAF on a Digifant2 volkswagen cabriolet and similar. It gave an idea of what the resistance should be between different positions on the connector through some positions. These would be different for each application.
Regarding "use a bmw one" there may well be a bmw VAF that will bolt on but you can be sure it will behave differently. There have been a lot of guys who turbocharged old 1.8L volkswagens who 'fixed' their lean running condition by swapping on a VAF from a BMW with a somewhat larger engine, which caused those cars to run rich instead. Some people's children, right?
But another concern with an aftermarket part would be whether the spring resistance on the barn door is - whether it moves the same for the same air as the original.
Years ago, my stumbling and low idle issues were gone after i replaced ALL of the vacuum lines, cleaned the IAC valve and its passage, and put band clamps on the air duct because the duct walls had been squished thin by the original factory wire loop type clamps. Of course, i did verify that there are no cracks in the duct.
If someone could identify a BMW part that physically fit, all the other things like spring pressures, resistance levels etc could be measured and compared.
Having an OEM substitute for a critical NLA part like this would be great.
I got doubts.
Trouble is it isnt constant. You have a range when the flap is closed, then a range when its wide open (it often has a circuit for fully open), but everything in between isnt linear. So testing one meter vs another doesn't help a whole lot when you are trying to find one from a different vehicle that is identical. The open and closed positions could be roughly the same, but everything along the switch of the carbon track is different.
I know enough about electronics to be dangerous, but why can't resistance values be measured and compared.
An open circuit at WOT is open, so that's easily compared.
Part throttle resistsnce could be compared or calculated too
If the carbon strip in one had the same resistance as another, and the swept length was the same, then 30⁰ rotation in one may well give the same resistance as 30⁰ rotation in another.
If the resistance along a certain length of carbon strip is known, and is consistent along its length, then two parts should be comparable?
If the carbon strip is not uniform width/area along the swept length, then things get difficult
They may not ultimately be the same, but still measurable/comparable?
The board I threw into my VAF was from a '90 Camry. Same part number stamped on top and looked identical to the naked eye - but that doesn't mean much. I will say it's working fine so far. Truck lacks power, drives like trash, and limps along just like it should!
Joking aside, finding a whole plug and play unit might be difficult (especially from an entirely different manufacturer). But if other Toyotas with a VAF carry a close enough equivalent board, then that could at least provide an inexpensive solution to keep the VAF going and the truck on the road while other avenues are considered. It also seems like the innards are almost always the only thing that would need to be replaced; can't imagine much happening mechanically to the housing. It's not complicated to dis- and reassemble.
We've been down this road before with BMW's, trying to find replacements for flap type air flow meters.
Measure it and you'll see the problem. The trouble is it isn't constant. Even if you hold it in place the value changes. It is that sensitive to movement, plus the problem is the carbon wears, so you can have two identical working sensors and both read differently due to wear. It honestly astounds me how it even works properly because it's both so sensitive, yet at the same time it has such a large operating range.
I should add you can find replacement carbon tracks (replacement PCB) for sale online that all seem to come from china. I haven't heard of anyone actually using one though. Normally you can clean the carbon and adjust the location of the contacts to run on an area of the carbon that hasn't got deep grooves worn in it.
I forgot to say, If you want to view the resistance of the air flow meter when moving anything, you really need an analogue multi meter too. Digital ones just don't refresh quick enough so you get erratic readings.
The other problem with finding a replacement from another vehicle is finding one that is a similar size. The physical size of the air intake / air flap changes, so using a smaller unit on a larger motor is going to mean the sensor is likely running fully open due to the increased airflow required by the engine. You could overcome this somewhat by increasing the spring tension, making the flap harder to open, but I suspect you are going to continually bounce between the intake being a restriction, the spring tension being too great, and the sensor leaning out.
In the BMW world, a company developed a maf conversion with mixed results. The version that just replaced the MAF and was supplied with a new memcal (ecu eprom) worked well. It was basically a replacement with small wiring changes to the loom. The version they sold that allowed a level of tuning was junk. Lots of people had constant problems with the ecu leaning out.
You can see the maf after the pod filter in the pic of my E30 below.
They originally had bosch flap style air flow meters.
Toyota ECUs are notoriously difficult to hack around with, so there will probably not be a chip update for these trucks.
Split Second seems to offer a programmable AFM to MAF conversion product. I wonder if anyone has successfully used one on a cruiser yet?
Mudgudgeon, you were correct. It ended up being a vacuum leak from the valve cover vent hose. I don't remember if it was the PCV valve, grommet, hose, or exactly what I did but it resolved the issue after a year of messing with it. I was reading my previous post and was sitting at 341,000 mi. I just got back from North Dakota over Christmas and good to go at 352,000 mi. I'm not a good poster but will have to share a fuel pump story from my trip at the right time.
how did you discover this? was the hose cracked or the valve itself? I'm chasing a stumbling idle, and have checked all the other vacuum hoses..
Bench tested mine and it wasn't within spec (previously rebuilt by Bavarian Restoration with good results over a couple of years). Going to do a VAF to MAF conversion, but in the meantime just went to the parts yard and pulled the VAF out of an old ('90) Toyota sedan and put the circuit board from that VAF into the 80's VAF (the part number is stamped on the board and is the same as that for the 80). Made a few adjustments to the spring as well. Works fine and should get me through until the conversion.
did you end up doing the VAF to MAF conversion?
I tore apart one of these VAFs at work when at HP and nobody could believe that pcb was capable of providing any functional data to the ECU.
eeek! bit of a bleak assessment.. definitely an achilles heel for these cars, with no known VAF to MAF conversions I've seen. A few places claiming to be able to rebuild and calibrate them back to factory specifications on a test bench... but who knows.
My approach was to buy a chinese one off of ebay to use while I sent the OEM one off to Bavarian Restorations for a rebuild. I ended up buying a second OEM off of ebay and sent both my original and the ebay OEM ones for rebuild and ran the cheap chinese one while they were gone. Now I have a rebuilt OEM spare to swap in when the rebuilt OEM one I'm running needs rebuilt someday.
yeah, that's going to be challenging for me, as I'm in Australia and they don't ship internationally. Either way, I'd be paying postage both ways, plus the AUD to USD conversion is horrendous atm. There's a place here that will refurbish it to "like new" for $900 AUD.... not cheap! Turn around time is within a week.
I had once pondered asking a place like Bavarian if it would be possible to take a new (china) VAF and modify it so it specs EXACTLY like a Denso unit that works. I tried a few of the available 3rd party VAFs in my 94 and none worked - at all. It was utterly terrifying to have my truck hanging in the balance by three unrepairable POS thin film solder connections and a few threads of wire as a rheostat on a .50 cent pcb board.
It would be great if Denso would do another run.
The chinese one I got worked fine for me, but I didn't expect it to work well for very long. I actually donated it to my local shop so they would have a known good one to use for diagnosis. I doubt Bavarian would refuse to rebuild the chinese one. For the cost, I'd buy one and send it to them without mentioning its provenance and see what happens.
