We've gotta Jumper!
For those of you who have been around long enough to recall member "docmallory", I purchased his rig a couple years ago. I'm just about to pull the trigger on lift and tires. I know its been covered but I am looking for peace of mind before I spend. This vehicle is going to be my semi-dd with planned capability. I plan on front winch bumper(currently non-winch ARB), Sliders, rear integrated hitch/tire carrier, tranny/tcase skid plate, drawer system, and some kind of MT rubber.
The F.O.R. lift is very attractive, but I don't want to regear for at least another couple of years. For those who are running 35's and stock gears: pros/cons please. If I run with a 33" or 305 I am looking at a stance similar to this>
https://forum.ih8mud.com/showthread.php?t=162860 (thanks antor)
Which brings me to the 295 Hankooks that measure in at 33.6" and will fill the fender-well an extra 1/2" compared to the Mickey MTZ's that "antor" runs . Or I could go with a choice of several makes of 315's / 35" which vary from 34.47" to 34.8". That is, if you all convince me.
Which brings me to OME..... I don't want to worry about a harsh ride on an unloaded rig. If I choose OME I am leaning towards a combo of the 2.5" medium spring rate w/ airbags, Bilsteins, and the 295 Hankooks. Does this make sense?
After months of contemplation and research I am looking for input to jump off the fence. :confused:
Thanks,
Baumber: 97 #1678 40th
Ive Had Stock Gears And 315's For About Two Years. I Noticed A Loss Of Power But The Tires Were Worth It To Me... Around Town No Problems But Its Flat Here... If You Have A Lot Of Hills Would Be A Pain... I Ran Geolander M/t+'s Untill A Couple Of Weeks Ago, I Just Switched To Toyos Mt's And They Are Way Heavier And Actually Effected My Power More Im Regearing This Weekend.....
That Looks Like A Lot Of Work To Type That Way.... ;)
I'm running 315s and stock gears... I notice that I'm undergeared, but it's pretty hilly where I live. Basically, I just leave the PWR button on and shift in and out of OD as needed. I've lived with it for a year and I'm okay with waiting, but gears and Longfields are def my next mod.
Thanks LAWMAN, weight of tire is the other consideration I've made but not all manufactures list weight in their website specs. Which brings me to another question: Would it be foolhardy to go with a TRD Supercharger considering they don't make them anymore. I mean: Are parts going to be a PITA to find if something fails?
Well the Supercharger has been really absolutely a non maintenace item for mine after 50,000 miles. I did replace the hoses and TRD no longet sells the hoses....I simply found some silocone hoses online and cut to fit......so yes, go with a S/C and you'll be fine down the road.
airlaird
So you got doc's rig huh?:flipoff2: I had money in hand and was only a couple days late according to Doc on making it happen. Thats a great looking truck!!
I had OME j's to begin w/ and no weight on the truck and thought it handled fine. If you are going to add the bumper/winch soon i might consider teh heavies up front. i never felt it was stiff till i added the slee 4'' springs, and hope ill have a bumper/winch soon to counter this.
I think youll be fine on the street w/ the 315's unless you get into some hills. offroad is where youll notice it but then you got Low to deal w/ that to a degree.
I've got stock gears with 35's, it's functional. Lower gears would be nice, but not necessary. I'm cringing at the thought of the total bill when I go up to 37's though, with gears and bead lock wheels added to $200+ tires x 5. Yikes.
-Spike
"So you got doc's rig huh?"
Yep, swooped right in, and I've been very pleased with it. :grinpimp: As far as hills go, I'm in southern Ohio and drive them every day. Also, when I want to go on weekend getaways, that puts me mostly in the Appalachias or Smokies. So I expect inclines.
I believe I'll stick with the 295's for now, and am still concerned about the amount of space between tire and fender with a 3.5 lift. Any more suggestions?
Thanks,
Baumber
850J and 863 springs. With the accesories you listed, you'll have just under 3" of lift and be setting fairly level.
Just ante up for the 35's. You'll find that the choice of tire, not size will dictate how much you want to re-gear or not. I have 33" Xterrains and always felt I could use lower gears, then I put a set of 33" GY Wranger A/T's on it and WOW it rolled so much easier! I would say that a set of all terrain 35's would roll easier than my 33" Xterrains.
You might want to contact Rodney at Wholesale Automatics. I would suggest getting the valve body, os you wont decrease the life of your tranny due to it not locking up when you push the power button, or are in 3rd. Not to mention it is a great upgrade. If you go with the supercharger you might be ok since the ungearing of the tires will be offset by the added power of the charger.
That's not the complete reason to have the valve body reworked. The clutches on 2nd gear will burn through with the S/C. It's a common issue on S/C tacos and 4runers with the same A343 as the 95-97 land cruisers.
Where do you live in S. OH?
I've got a stock (for now) 80 with the Hankook 295s. OME lift is in the garage waitng for me. let me know when you wanna sell the non-winch arb cheap.
Get the FOR kit with 35's. Regear when you can. Just do it once, the way you really want it, that's the point of that suspension/tire combo. Going 295's vs. 315's is not going to change your model. Quite honestly, I haven't ever thought 35's where any worse than 33's. They both sucked, but I live at high elevation with long hills, and OD off is a better match on 35's than 33's because the RPM's are in a better range.
I would not run Bilsteins with regular OME springs, if you are going OME buy the kit. OME springs seem to need more valving that you will get with Bilstein 5100's.
Simply said, if you find yourself trying to mix and match OME to get that perfect combo...you are the right buyer for the F.O.R. suspension.
Decision Made
I decided on the Hankook 295's and F.O.R
I had to be in Georgia so I was able to justify the drive to Frankie's for the install. (I had the tires put on week before). Frankie and I took most of a Saturday to do the just over 3" lift.
This was several weeks ago so the springs have had a little time to settle.
I didn't go w/ the full 3.5 as I don't think I'll need it, even with 35"s, without a 3-link.
I've yet to get to an alignment shop for castor readings. It feels fine. By fine, I mean there is no vibration in the steering wheel as of yet. Prior to CC there was no vibe as well, but there was a noticeable "roll" from incorrect castor. After CC this roll virtually disappeared, but is not completely gone. The ride is firmer than the the stock 170,000 mile springs. This is not a surprise.
I don't feel unsafe driving this vehicle by any means.
Bottom line,
I like it and so does #1678.
It was late by the time I was able to try some poser shots. I'm 6 foot.
:cheers:
Have you spent time in Frankfort, KY with that rig this summer? I keep seeing a 40th with a front ARB and Ohio plates around town. If its you, I'm the guy with the big 40th that passed you in traffic once. It it's you PM me...we'll hit a trail one weekend.
