installed F.O.R. 3.5" last weekend
So Cal
last weekend I installed my FOR lift , it was an easy installation except the bolts for the front bump stop spacers were 5/16 SAE not 8mm metric. Also the rears were metric, but too short.:crybaby: Other than that every thing went in nicely.I actually got about 4" of lift . It handles much better than stock ( I have 145000 miles on stock springs, shocks look like they have been replaced,I bought used)
the ride is very good,but not quite as smooth as stock. I am very happy with the results. Cant wait to wheel it :D
however I did notice my axles are offset:confused: if i measure from the inside tire to the frame its about 1" off in the rear,and 1/2" off in the front. Will an alignment fix this? Any suggestions will be appreciated.
I wanted to post pics dont know how to resize to fit, some help please.
which would be better ,the rods or the joints? thanks
I don't know anything about the other stuff so I'll leave that to the experts :D
As for resizing pictures...Assuming you have a windows based PC (because if you had a Mac it would be simple right? :lol:) the easiest way I have found is to open the picture in Microsoft Photo Editor (right-click and open with if pics open up in some other program for you), click on "Image", then click on "Resize". Change the units to pixels and change the width to 800 (or less) and click ok and save the picture or do a save-as so you don't mess up the original.
The above works well for doing a few pictures. If you are trying to resize a bunch of pics at one time Microsoft has a handy and free resizer program (along with other junk) you can get here --> Image Resizer
This program will allow you to resize as many pics as you want with a simple right-click of the mouse and then selecting "resize pictures". There are 4 default resize settings as well as custom sizing. The tool will also create copies of the pictures adding small, medium, large, etc. after the name so your originals stay original :D
I usually just resize my pics to the medium setting (largest pixel size MUD allows) and then make sure the new file size is also within MUD limits (120KB or less) and then post away...3 at a time ;p
thanks Corsiar 23, here's my pics
before
Forgot to mention, after you do the manage attachments, browse and finds the pics, don't forget to hit the "upload" button before closing the window so the pics attach :D
You can attach 3 at a time in MUD and you have a space limit unless you purchase a silver star (recommended to help support MUD). The other option would be to use Photobucket or some other picture hosting site and link to pics that way.
Edit...Seeing pics now :)
oops , think i deleted pics these are the after.
MEAN looking rig.:mad: I like it!
All dark is cool... now black out the chrome grill
thanks, I had help removing the flares with a large rock. I plan on blacking out the grill later.
Looking good, lets us know how it goes.
Frankie,
What size tires are on that green rig?
With the ARB already installed, the factory springs were below a normal stock measurement, so the total difference is greater. In other words, the bumper is going to compress the old stock springs more than the new springs, giving you a bigger lift measurement.
Antor looks pretty much ready for 37's on that bad boy :D
Shezaam :eek:
I think I caught your before pictures before you deleted them but weren't you showing about 3.5" between the top of the tire and the bottom of the wheel well before and now you have like 8.5" or so?
So you netted a 5" lift :confused:
