Wet around knuckles
Chatham NJ
Ive been noticing wet knuckles with grease that will ball/wipe off. It's not dripping oil just wet around the studs and grease comes out around the wipers. I've got a 4K mike trip coming up and was wonder if this is normal...all new oem parts in the front cv's,shafts everything from diff out. Used Valvoline palladium to refill and install when I had my shop do the rebuild.
Check the gear oil level and color, that will give you some insight.
Thanks i'll be changing it out soon so i guess that will determine the fate of the seals...now i really should have used that search button!! :confused:
seems like the palladium is a bit more runny/other greases run/separate their oil differently
How long ago was the rebuild? I found using OEM seals that one knuckle got contaminated very quickly perhaps within a few months? Changed the seal for another OEM and that stayed dry, the other side started to leak after a couple of years. As per @mct75 I would check the colour for your diff oil.
If you are mega short on time I would change out the gear oil and top the knuckles off with Moly grease, that will cover your 4k trip. If you have the time then perhaps pull the shafts and fit some Marlin Crawler seals with the double lip?
OEM is great if the shafts are straight and with no wear scribed into the seal contact areas but, given the mileage these vehicles are approaching then there may well be some wear?
regards
Dave
All parts are new OEM the rebuild is probably 15k miles ago? i forget. i've kept the knuckles pumped with grease. they just seem moist around the wipers/stud bolts but no dripping etc
If you keep them "pumped" with grease and it's only been 15k since the knuckle service then you have probably over serviced them and that's why it's showing up on the outside. FWIW, I just took my knuckles off and there was zero gear oil in the knuckle but the outside had a light oily look to it, which can't really be helped. Last year I put 100 pumps of my grease gun into each knuckle and for the next 6 months the amount for grease escaping past the wiper increased until the grease level in the knuckle decreased to its happy place.
I think it's easy to over service the knuckle cavity if you are putting grease in there every oil change or something like that.
A little moly in your diff isn't such a bad thing and you will definitely know when the gear oil is washing the grease out of the knuckle because oil will be dripping from the knuckle studs.
I have this same problem but my grease is coming out in chunks. It doesn't look like diff oil has mixed with the grease but there is a substantial amount of grease that builds up on the knuckle after escaping the wiper seals.
I originally thought it could be due to clogged breathers but extending the breather lines with new hoses did not seem to stop the problem. Maybe I overfilled the birf when rebuilding the front axle and it is still getting rid of the excess grease from inside.
I did a front axle rebuild Jan 2016 and ~10,000 miles ago. I have not put any more grease inside the knuckle.
PS front of knuckle
PS rear side of knuckle
DS rear side of knuckle
I have the same look. I am not sure if I should do anything about it as I will be putting harrop locked third in the front soon.
