For Sale Wellington, FL; 2006 4Runner V8 RWD Turnkey Vehicle
Florida
Year
2006
  1. 4Runner Gen4
Mileage
142680
Color
Green
Outside Link
https://www.facebook.com/marketplace/item/7475968909132158/
VIN# JTEZT14R668010079 Very well maintained 2006 4RUNNER 2WD (RWD) V8. I spent almost a year searching for this vehicle and this was the best I found. Florida car its whole life, no rust. Low mileage for its age and confirmed actual mileage; most of the 4Runners I found had been rolled back at some point. I purchased it in July of 2021 from an elderly man who was anal about having the vehicle be as perfect as possible. Carfax shows a front end accident in 2013, did not see evidence of it being anything more than a minor accident when I had the car inspected prior to purchase. Oil has been changed religiously at 5k mile increments with Mobil 1 synthetic and OEM crush washer. Only Chevron or Shell top tier gas used. I never towed with it.
The vehicle has been plasti dipped in a Dark Green color, Jasper Green; Jasper Green Car Kit | Performance Series Plasti Dip - https://www.dipyourcar.com/products/jasper-green-car-kit. The paint on the vehicle had started peeling and I wanted to have it protected so it didn't rust. I have added a few pictures of it before the plastidip. The plastidip can be removed. I will be including extra plasti dip for touch ups. The passenger Rear Door Cladding was damaged by a shopping cart and replaced with a brand new OEM cladding. The door on that side needs a little firmer push to close than the other doors. I will include additional clips as the piece will sometimes come slightly loose and needs to be pushed in. The lcd screen has an area that's no longer illuminated by where the date and temperature is. The tint has scratched in some places but is still fully functional.
The vehicle is in very good to excellent condition both inside and out and I have maintained and described it to the best of my abilities. The dash looks great with no cracks which is common on these and the GX470's. $11,000 FIRM, please no offers—Cash only, Vehicle is being sold as-is. I invite anyone to have the vehicle looked at as it's in excellent condition.
It's located in Wellington, Florida 33449. I am selling since we don't use it enough. Clean title in hand in my name.
Here is the maintenance from the previous owner up to me. 11/16 89k miles Timing belt, water pump, crank seal front, seals, coolant all belts, Trans fluid, power steering fluid, brake fluid, differential fluid, spark plugs, weatherstrip (all done at Toyota when the elderly man bought it—see attached)11/16 Pioneer head unit with backup camera11/16 Tires & Brake Pads 89k miles10/17 Magnaflow Exhaust 10/17 (sounds great)Front seats redone professionally in leather 3/19Headlights replaced with BMW style Halo 8/19Battery 10/20
My maintenance since I purchased the vehicle is as follows:
8/21 114k miles-changed cabin air filter, cleaned engine air filter (reusable K&N filter); Metra volume module which allows you to adjust the volume with controls on the steering wheel to be compatible with the Pioneer head unit; Rostra driver seat heater-same as OEM in the limited models. New OEM cargo nets and hitch cover. 9/21 NEW Bilstein 4600 front and rear struts and alignment. 11/21 Oil change1/22 Tighten valve cover gaskets3/22 Oil change 4/22 Engine and cabin air filter clean k&n5/22 Oil change 8/22 125671 miles--Oil change, new TPMS OEM DENSO sensors x5 (including spare tire under vehicle and reprogram/reset TPMS), 4x NEW Michelin Defender tires; OEM Pads + rotors rear; OEM Front Pads+rotors+OEM calipers. NSK Wheel bearings + hubs front (purchased from trusted member 05Taco4x4 at Tacomaworld.com forums; Bled brakes and Alignment11/22 130625-Oil change+align camber 12/22 New OEM Gas cap2/23 135572 Oil change. Cleaned engine and cabin filters7/23 Wheel balance8/23 140,510-Oil change; clean engine and cabin filter9/23 Alternator Oem Denso 9/23 OEM Window Regulator rear passenger (old regulator pulled off a little of the plastidip-see photo)1/24 New Battery2/24 New Wheel Bearing
