Welding to your frame....
Surrey
buying sliders for my HDJ81. Just wanted to know your guys thoughts about welding to frames.
cheers
I wouldn't weld the sliders directly to the frame. Instead weld a scab plate with some sort of mounting system on it.
The scab plate will spread the stress out, and allow you to unbolt the sliders should the need arise.
There's a couple of threads on good mounting systems if you search.
I welded mine with 1/4 inch backing plates and gussets.
I preffered them welded.
Did not want to make a mounting system for them.
Everyone has there own preference with regards to what they do to there rigs.
If you feel that for any reason you will need to take them off then do not weld them.
Mine are welded to the frame.
I've talked to some fabbers about this because I heard it wasn't a good idea. Every fabber I talked to said he has never seen an 80 frame fail due to welding on it, but that they always welded the slider to a diamond shaped scab plate, then welded THAT to the frame to distribute the stress on a non-vertical plane.
my plan...
is to buy the sliders from trailgear, with the plate gussets. Check them out and let me know. I think thats the best idea myself. And yes once there on I'm not planing on taking them off
cheers
You want something like this:
What cat protection?
You are supposed to protect them?:D
Call Adam at 4x Inovations he has some nice sliders as well with the kick out in the rear in you want to weld them to the frame and they are not to expensive.
I'm not familiar with the 91 HDJ as it relates to cats, but if it has exposed cats like my 94, you are going to have to fab up something to protect them...the TG's don't have anything for that.
I'm going to be running a 3" pipe from front to back. No need for mufflers and cats.
Jason- just make sure you get the kick out at the back. Saved my butt a few times now.
Mine are welded on. They take a BEATING. ALOT.
D
Howdy
In despite that welding the slider direct to frame is easy and strong, I don't believe that I want this to do on my truck! What happen if the sliders are getting in a serious wrack and you want to replace them? Torch will not help you and will be the number one enemy to the frame.
:beer:
There are ways to remove welds on a frame rail other than torch. They may be time consuming and more painful (to you, not the truck - sawzall), but there is more than one way. I am not sure if the heat applied by a welder is much more or less than the heat applied by a torch (assuming professional people behind the tools). That would be interesting to experiment, but thats for a different day.
Also, there are ways to *fix* sliders that are welded on and were involved in bad accidents. But a trick is to use some strong stuff before hand and you may never have to worry about it.
Welding or bolt-on is really a preference that one must choose. Both have their ups and downs.
Cat protection and side shots.
iptman those sliders and installation is awesome! IPOR does great work. Wish they were in Tejas.
I would also go with welding, believing it would minimize weak points under pressure.
Welding! The Horror! Never weld anything to your 80!
Come on Nay! There are several things that could and should be welded to my 80. If I could weld it would be one big weld. :p
