Welding question
I doubt that it will be a problem for mild steel (less than .15% carbon, which is the most commonly used steel). It doesn't contain enough carbon to harden or become brittle upon quenching and the parts would need to be quenched when red hot or above about 1650 degrees F, which isn't easy to do when welding on thin metal. It air cools to quickly. Don't obsess about it. Get a copy of "Metals and How to Weld them" from Lincoln Electric for $10. We used it as one of the text books.
Thanks for the recommendation. I'll definitely have to pick that up. I know next to nothing about the actual compositions of different metals but I want to learn. I figure the more I can learn about that, the better welder I can be.
'74, I've got pics in my thread here: https://forum.ih8mud.com/60-series-wagons/469658-making-new-brackets-my-mazda-seats.html
The ASTM A500 steel tube you used is a carbon alloy and is heat treatable and should not be water quenched when it is red hot.
It is useful to know what you are welding on and how to weld different types of steel.
Do you think it affected the strength enough to be a concern for a seat bracket?
Sent from a phone, and stuff
Pin_Head said:
How would I know? I don't know what you did to it.
Ha, touche'. Dipped them in water to cool them after I welded. Though they weren't red hot, so I honestly don't know if that'd make a difference or not.
Pin_Head said:
It needs to be red hot (approximately 1300F) to harden low carbon alloys like A500. You should be OK.
Cool beans. I definitely gotta get that book so I can learn more about what I'm doing....
