Weird Thump
LFD2037
TEXAS LEXUS!
Wax., TEXAS
I'll try to explain this problem as clearly as possible.
Come to a COMPLETE stop
Let off brake
Apply normal throttle
After maybe 5', I feel a 'thump' that seems to start at the rear of the truck & feels like it continues all the way to the front ending with a forward/rearward 'bump' in the steering wheel (this process takes < 1 second total)
I can literally see the steering wheel bump forward/backward (not left to right rotation) like it's being bent
Almost like getting rear-ended lightly
Is this a sign of a sticking rotor? That's the only thing I can possibly think it could be. It doesn't feel like drive-line slop.
Ideas?????
if you quickly shift into neutral as you accelerate from a stop, does the issue occur?
Have not tried that but will in the morning.
It does NOT do it if:
1) I don't come to an absolute complete stop
2) I accelerate from the stop very light on the throttle.
Noticed yesterday & today it doesn't do it in the rain. Weird.
I have this same issue. Anxious to hear any thoughts.
Good sign it's a rubber bushing gone bad.
When they dry out and noise returns... spray them down one by one, confirm the noise each time.
It's not really a noise. It's a thump/bump type feel. It comes on like a wave from the rear to the front. Like it's loading up energy then thump.
No joke, buddy of mine who owns a shop had a client bring in his Benz with a thumping sound that would start and stop in a forward motion...turns out it was his bowling ball in the trunk
Sent from my SAMSUNG-SM-G900A
Ha!!!!!
My mother had this same scenario in her 2007 Altima. She was freaking out that her car was going to fall apart or something, went to take a look and found 2 gallon jugs of water flopping around in her trunk Lol!
Seriously though, it sounds like the rear control arm bushings need inspected first and make sure if you have a hanging spare tire that it is tight and not flopping around.
No spare. I'll check all bushings tomorrow since it should be done raining. Thanks.
All 8 rear upper & lower control arm bushings have decent sized cracks in them & I can rotate them by hand ever so slightly (1/32"). I think they need to be replaced & is probably my problem.
***ETA*** Do the OEM rear control arm bushings have voids in them all the way thru? Mine do.
Check your rear control arm bushings & report back.
The upper control arms and bushings are new. I will check the lowers.
Thanks
The lowers did not look too bad. They had some surface cracking and were soft so I replaced them anyway. Along with all of the sway bar bushings. (They were toast) This did not solve the issue.
What does not make any sense to me is the noise/feeling reduced considerably after changing to 315 size tire from 285s. I know my lug nuts were not loose.
It's the ghost of Antonio Lopez de Santa Anna.
F&$% Texas!
I have nothing useful to add. But this sure sounds scary. Hope you figure it out.
