Weird Starting Issue
This is a regular prob with the 60s, is a bad coil ground.
Pull the coil holdown cage bolts. Clean bolt contacts and holes, reattach.
Now put a new ground wire from the ignitor on top of the coil, to a solid body ground. \
And if you want solid start, and longer lasting rotor and cap, put new wire from those coil cage hold downs to the block. 100s have a stock ground set up this way.
Bonus is brighter lights, less alt stress, and saves the dash wiring from shorting.
This is coming wout the grounds.
Is my alternator about to eat dust?
When the switch itself is going bad or there is a bad connection, the NSS wont send the proper signal to the ECU allowing it to start.
To be clear, the starter circuit is very simple on these trucks and has nothing to do with the ECU. The NSS is certainly a possibility, but the ECU could be removed and left in the yard without effecting the starter.
Seriously dude? You really need to spend some time looking at the schematics for the truck.
The starter circuit has nothing to do with the coil/igniter or any other ignition component. It is a completely separate system, including ground points.
