Little backstory,
9/93 build date, 239k, headgasket replace at 160ish. Runs great, runs strong, never had a bit of problems.
At gsmtr it tried to cut out but i caught in and brought the rpms up and it didnt die.
For the past week, every morning on my way to work it dies in the same spot. I pull up to the light stop for it to turn green and it cuts off. When i start it first thing in the morning it starts right up, idles fine. The drive to where it dies is about a mile and is in a neighborhood so the speeds are about 20mph. There are 2 other stops before the light that it dies at. Its also done this once on my way to lunch. Same exact distance, same exact 2 stops before it dies.
Its done this a couple other times in the past year and a half but now its doing it everyday at the exact same distance.
When i go to restart it will fire up run for 3 seconds and die. Then it wont do anything then in about 5-10 minutes (time varies) and after numerous cranking attempts it will start, idle extremely rough and then smooth out and run fine for the rest of the trip to work.
Since it started doing this Ive changed out the maf, and the iac, i recently cleaned the injectors and changed the fuel filter, the wiring at the egr looks to be in good shape. Plugs and cap and wires seem to be ok.
Anybody got any ideas or has had this similar problem. I have no clue where to start.
Will
Will
