weird bumping sound
Durango, Colorado
Website
instagram.com
after driving on a dirt road littered with potholes i noticed that whenever i now go over even a small bump theres a strange sound on the passenger side. it kind of sounds like two blunt objects are making contact. i tugged and knocked on all the suspension parts and exhaust and nothing seems loose or broken. ive read it might be my sway bar or bushings somewhere but they seem fine when i took a look. any ideas as to what it might be?
I'm not real familiar with the 1fze, but I just fixed a similar problem on my 1991. After a year of searching it ended up being the exhaust contacting the frame just behind the y pipe. It wouldn't make any noise when pushing and pulling, but the hanger on the y-pipe had cracked allowing for just enough play.
After a 4" Slee lift my bump stop extensions where rubbing/catching on the springs. Made a weird bumping sound. Removed them thus eliminating the problem.
ill have to check that out.
You might not be able to impart enough force to properly check the suspension for being tight. Go ahead and check the torque on all the bolts. Make sure to only check the bolt head/nut with the washer underneath.
I had the front sway bar break off the mount. Took forever to find it. The bushing at the mount wear out fairly quickly on mine.
Had the broken exhaust mount problem too. Try using a pry-bar on all joints, mounts and bushings.
Look at motor and trans mounts.
So the shock mount was loose and clunking? Or literally unbolted?
I have been running on wore out shocks for years and enjoy the ride it offers with OME springs.
After I rearched the springs in the 60, I ran with no shocks and enjoyed the ride.
Use to buy Monroe Gas Magnum but got tired to my fillings falling out.
Why cant I just use a telescopic rod with a big electromagnet to control the speed and recoil of the springs?
