Weird ABS malfunction????
Hi all. I was hoping someone could help diagnose a problem I have experienced 3 times now.
Yesterday I was driving the cruiser at about 50 mph and had to reduce my speed slightly. When I applied the break it felt as if the ABS system was activatiing (pedal resistance) and the car swerved to the left. It was a bit scary. I was not braking hard and there should have been no reason for the ABS to activate.
This has happened 3 times now, but most of the time the braking is fine. The ABS light has been intermittantly on and off again since I installed my birfs, but this problem just appeared and I did the birfs 9000 miles ago.
There have been several similar threads recently. Conduct a search and read them.
Pretty much everybody has said to check your ABS sensors, which includes pulling them out and cleaning them. Good luck.
