Weight
2000 pounds = 1 ton. The landcrusier is more like 3.125 tons.
No problem.
GVWR is the max weight the vehicle should weigh with a full load.
Here is the wikipedia version:
A gross vehicle weight rating (GVWR) is the maximum allowable total weight of a road vehicle or trailer when loaded - i.e including the weight of the vehicle itself plus fuel, passengers, cargo, and trailer tongue weight.
The difference between gross weight and curb weight is the total passenger and cargo weight capacity of the vehicle. For example, a pickup truck with a curb weight of 4,500 pounds (2,000 kg) might have a cargo capacity of 2,000 pounds (910 kg) pounds, meaning it can have a gross weight of 6500 pounds when fully loaded.
UK spec cruisers with a certain towbar combination can tow 7500 GVWR, there is even a warning plate that should the vehicle be used to it's full potential it should be fitted with a tachograph as per heavy goods vehicles!
Many countries had downrated GVWR plates to meet with certain laws.
regards
Dave
Dont have the specs in front of me, but thought curb weight was around 47-4800? Maybe someone can confirm/deny ;)
That's how I understand it.
What is the weight of a land cruiser? Looked at the tag on the door and it said GVWR is 6250. So a stock LC is over a ton?
I find that it's heavy enough to start to bend light... and I get younger whenever I drive it. Sucks when you get a compact within the event horizon though.. it's stuck there forever.
The easiest way is to go to the dump/waste management facility with trash and get your truck weighed.
Mine was 5420 lbs. About 2 & 3/4 tons. Stock except for tires, Slee short bus. And some junk in the back.
Put mine on a CAT scale...
ARB upfront with Warn 9.5xti
Slee rear with tire and 33 M/T
3 OME lift
4 33 M/T
full tank fuel
co2 tank
recovery kit
metal tech sliders
6500lbs
You need a S/C to move that weight.:flipoff2:
My '93 stock was right at 5000 lbs.
Adam
My '97, when it was stock, was right at 5200 lbs with 3/4 tank of fuel. The tank will hold about 150 lbs of gas.
ran my '97 over weigh scale...stock except for lift and 285's...ran up 2250 kg -> 4950 lbs. I was a little surprised!
I hauled an entire pallet of 48 bags of playground sand home in the back of my 80 series
50 lbs each = 2400 lbs
yeah - it was riding on the bumpstops
