I've been running a Weber 38DGAS w/electric choke for some time now, and am happy with it, though there have been some times... I still have my original carb I took off at about 30K miles, and came pretty close to sending it in to Jim a few times. When I have the spare funds, I will send it in so it will be ready to install when I need it.
Anyways, a couple things to think about...
How come it was "dirt cheap". If it leaks air around the butterfly shaft, you will not be very happy with it.
Do get some main jets and air corrector jets. I keep a couple values in the glove box. When I went to Rubicon, I had the truck running real nice, but when I got there, I discovered I had to open up a vacuum leak just to get it started and backed off the trailer. Of course that was before I kept different jets in the glove box
. I carry a pair each of 135, 145 and 155 main jets, 180 and 200 air corrector jets. The larger the main jet number, the more gas, the larger the air corrector jet number the more air. A larger air corrector jet has the effect of a smaller main jet, with finer adjustment steps than the main jets provide.
Be careful of the adapters you use for connecting it to the Toyota manifold. They are notorious for leaking air. Watch the bolts that hold the adapters together, the provided ones are just a hair too long, and when tightened, they spread the lower joint interface. The studs that hold the carb also have this problem. The bottom of the studs end on the top surface of the lower adapter plate, so if the nut that tightens down the carb grabs the threads, it will rotate the stub, which pushes it into the top of the lower plate, spreading that joint. I mic'd out all the adapter plates and cut all my own screws to lengths that can not protrude below the plate they thread into. I also scew the carb down, instead of the using the studs. I gasket each interface with a single layer of the thin gray gasket paper that I've sprayed with copper coat.
If you use the stock Toyota insulator spacer below the carb, you can cut notches into that spacer to clear the moving parts under the carb, and elongate the mounting holes in the carb base to match the stock Toyota pattern, eliminating the need for any adapters. I ran this when I ran the stock exhaust manifold. With headers, I want as much heat as possible to transfer from the manifold to the carb so I use the two metal adapters that translate to the Weber bolt pattern instead of the insolating spacer. You need something to raise the carb so the moving parts under the carb clear the manifold.
If you get the rebuild kit from Redline, or your carb already has one in it, watch the fuel bowl inlet, it comes with one that is too small. If it has a 200 stamped on it, it is too small, you need the 250 one. A 3/32" drill bit should fit in the orifice loosely. Becareful on the float adjustment. I can't remember why just now, but I remember it being somewhat confusing, and having to figure it out each time I do it. I have the Haynes Weber Carb book, and I read the procedure out of the book as well as the Redline instruction sheet to figure out what I am supposed to do.
If you are running the stock air cleaner, make an adapter between the air cleaner and the carb, don't use the stack of adapters under the carb to bring it up high enough. I attached pictures and drawing for the adapter i made in a recent thread about Webers and air cleaners. If you have a symptom where it goes weak and hesitates when you give it gas as you are heading up a hill, check if the problem goes away by removing the stock air cleaner. If the alighnment is not right, tightening down the stock air cleaner can push down on the intake manifold opening up an air leak at the head. This is also a symptom for having the smaller bowl inlet valve.
Pay attention to how the throttle is connected. A popular way is to use a cable, which is what I have. I believe MAF sells a means of adapting the linkage. The turns in the cable are pretty severe. I have had a cable break on me inside the housing, indicating that the curves are too severe. That particular incident was pretty exciting, and provided me with further proof that there is more to this life than what meets the eye. Being my daily driver, I replaced the cable right away, then later I turned the carberator around, mounted it 180 degrees off from convension. I replaced the throttle cable assembly again when I turned the carb around. I pulled that second cable out of the housing, and saw that at one point in the housing, the cable had frayed to the point where it was holding on by only one thread. The break and the near break were both at the turn at the firewall. Turning the carb not only removed the sharp curves on the throttle cable, but also positioned all the adjustments much better, even the mounting screws are easier to get to now, the two screws that are along the valve cover are no longer the ones under the carb over hang, and the idle speed screw now faces the fender and in the open, instead of facing the valve cover and around the master cylinder. Turning it around though gives you a small but problematic offset in the top of the carb if you are using the stock air cleaner. I will highly recommend that if you don't turn the carb around, use the linkage type throttle, and if you are running a cable, periodically pull the cable out of the housing and look at it. If you ever feel a catch in the travel of the throttle, replace the cable. Mine broke as I was entering a west bound tunnel on the freeway in the late afternoon/early evening (if you think about that a minute, you will realize that everyone entering that tunnel at highway speed is completely blind).
The Weber is sensitive to "dirt" in the fuel. I have several filters along the line, and still have to periodically take the carb apart to run cleaner and air through all the ports and pathways to clean out some "carmal".
Well, I've already typed this long enough that few will actually read what I've spent the last two hours making sure I entered correctly; so I'll stop now. Hope someone finds it useful,
gary
