Any work done that involved the harmonic balancer?
Needs to be torqued to 304 lb-ft. This drives the ps pump and oil pump.
Then it's worth checking.Not that I know of. But I have owned it about 1 year and it was like that when I bought it.
When the truck is running pop the cap. you should see some movement.
Sounds like the pump took a dump
Need to source 30 mm socket. For what it’s worth it didn’t look like it been messed withVery com.on for crank bolt to be loose enough to allow the power steering and/or oil pressure to perform at less than optimal levels.
