- Thread starter
- #21
LX stock bumper turn signal to clear lens signal in the LC position notes are as follows:
As mentioned above, I saved the stock wiring harness that has the fog light connectors and turn signal connectors on it. I spliced the fog light wires to the Rigid connectors then used the stock turn signal bulbs as a direct fit to the DEPO corner lamps sold by @ranma21.
Here is the back of the stock corner lamps:
In my hand I'm holding the stock LX turn signal plug assembly (top) and the stock parking light plug assembly (bottom). The bottom is what fits in the small housing in the stock LX corner lamp.
This shows the DEPO clear corner lamp (top) and the stock LX corner lamp (bottom):
Here is the back of the DEPO clear corner lamp:
Much to my surprise, the stock LX turn signal plug assembly (in background, bottom plug) is a direct fit into the DEPO lamp. I bought a couple of OEM parts to make the whole thing work (top plug assembly in the background) but none of it was required. I just twisted in the stock turn signal plug and everything was set. Simple swap of things and now my turn signals are in the corner lamps.
End result:
End result:
