Ok, so my machinist is ALMOST done rebuilding my 78 2F. I have purchased a new 4-row radiator, electric fan, hoses, upper/lower thermostat housings, aluminum overflow tank (and a TON of stuff not related to this post $$$). I am coming up against some difficulties finding the right water pump.
I do not have a mechanical fan anymore, so I don't need a fan clutch provision.
I do not have a factory oil cooler, so I don't need a provision for that either.
I have found water pumps with one or the other provisions mentioned above, but none (except JT Outfitters) with neither provision. I have reached out to JT Outfitters and this is what he had to say...
"We do have water pumps without the fan clutch and oil cooler, but it may not work with yours because the sizes of the pump and which pulley it takes may be different than what you had originally. The easiest thing is to replace it with the type of pump that was on that engine originally. The part number of the 2F pump without a fan clutch or oil cooler is 1701190 on our website, but like I said, it may not line up with what you had before or the pulley may be a different type."
My block had no water pump on it when purchased. So I have no frame of reference on this. I have never had to worry about this sort of thing on my Mustang or Bronco builds. I just kept whatever water pump was on it and trashed the mechanical fan and clutch after installing electric fans. I just did this on my 92 beater Bronco
So what is the deal with all the different provisions for FJ40 water pumps? Will a water pump "with fan clutch" work for me even though I won't be installing a fan clutch or electric fan? Are the pulleys the issue? If so, I can use whatever pulley is necessary on whatever water pump will line up with my block.
Apologies if this is covered somewhere. I did a search, looked through a few posts, but nothing seemed to really answer my questions.
P.S. Spector has one (I think) for like $200+. I'll not be going to them
... unless I absolutely have to.
