Water pump?
Rosamond Ca.
Are all the years 2F water pumps the same? Do any years flow better than others? Mine just crapped out, and I just want to know if I have options.
Different years have different lengths. Some have fittings for an oil cooler and some don't. Look at the SOR page for water pumps and match it with what is in your truck. I doubt there is any appeciable difference in output between models.
so to answer the question, no they are not the same.
i preffer the ones with the oil cooler fittings.....because you can use an oil cooler.:flipoff2:
however depending what year you have, you can upgrade.
later models have fan clutchs rather direct drive fans.
the hot set-up is the later pump with O/C fitting, for use with the clutch fans.
I am running an electric fan, so that's a non issue, bit I do like the idea of an Oil cooler in the future...hmm.....
Hi All:
No, the 2F water pumps are different lengths. Learned this when swapping a 2F from a FJ55 into a FJ40; the water pump on the '55 engine was longer!
Regards,
Alan
Seattle
