Water Pump
NOW in Texas
How can you tell if your water pump is bad?? There's a squealing, whining noise whenever rpms go up or when i'm accelerating. Not that loud but...i can hear it. So far no problems yet. Any thoughts?
Well can't you just open up the radiator cap once the truck is at full operating temp (meaning thermostat open) and see if the water is circulating? For me that would be step one to know. The squealing could be from an idler pulley. I had one go bad on me and it sounded like hell.
:eek::eek::eek::eek:
Oh...my...god...please tell me you're joking about this.
Ever read the warning on the radiator cap? You think they're kidding?
This is a very dangerous suggestion. The radiator is pressurized when the engine is running and the water/coolant is very hot at full operating temp. If you try to open the radiator cap, you will see a geiser under your hood. Hopefully you have a face shield to cover you face and apron.
Please Do Not attempt this procedures.
When the weep hole is leaking the pump is done. It will squeak and squeal before that point. However it can be hard to localize sounds on the front of the motor. There should be no lateral movement in the shaft. If there is lateral movement then the pump should be replaced.
DUDE, WTF ..... DO NOT DO THIS !!!!!!!!! GODD WAY TO GET A FACE FULL OF REAL HOT WATER & STEAM ....
