In the last couple days my 79 fj40 has started acting funny... at idle (like at a light or drive thru line) the heater stops blowing hot and the temp guage starts to climb (and appears it will keep going). If I rev the engine or start driving we go right back to normal. I threw another thermostat in tonight and it didn't make a difference.
I assume the water pump is going out? You agree or have something else I should check out??
Assuming that is it, is there any reason I can't put a water pump off an 85 fj60 that I parted on the 40? I would expect the 2F's to be the same in both, but the thermostat housing is different (4 bolts holding the top on in the 60 vs 2 bolts in the 40) so that makes me wonder if the water pumps are interchangeable. Any wisdom for me here?
TIA
TIA
