Water Pipe Part #
Los Angeles, California
Does anyone know the OEM part number for this water pipe or where to purchase a new one ? Pic attached Thanks guys
The pipe is 16351-66010 but you may also need the 3 O'Rings which are 90301-29006 and if you mashed the bejesus out of the bi-pass pipe then you will need 16268-66010
No hijack intended but I just did this last night.
BRH (big rubber hammer) using a few light taps top side-to-side, then wiggle, wiggle, wiggle, then pry with large screwdriver under lower base/lip, wiggle some more while pulling up. Avoid prying between the top of the pipe and the head with a metal tool (don't want to damage the mating surface).
FWIW
FWIW
In a perfect world....
